Full Version: Kodi 16 rc3 GLES issue?
I made test build of Kodi 16rc3 (armhf Buildroot 2015.11.1, Amlogic S802). While all other versions of Kodi are working fine with Mali 450 r5p1 kernel and userspace libs, 16rc3 behaves strage.
Only resolution that requires enabling freescale works properly (2k4k), 720p/1080p are shown as on picture below.
Any ideas?
Log: http://xbmclogs.com/pphwlwb7o
Screenshot:
Quote:18:07:55 T:3033288704 NOTICE: Found ([email protected]) at 18, setting to RES_DESKTOP at 16
18:07:55 T:3033288704 NOTICE: Checking resolution 16
18:07:56 T:3033288704 DEBUG: CreateWindow: Created surface of size 1920x1080
The used resolution does not fit the framebuffer configuration.
(2016-02-11, 18:58)fritsch Wrote: [ -> ]
Thanx... I blame lack of sleep for that, it was my fault. Merging error Smile
