2016-02-12, 07:00
Hi I am using a FireTV stick for Kodi and WMC with ServerWMC backend and although I had some issue with stuttering and de-interlacing but all i near perfect. The only problem i have now is that the playback of live TV and mainly Ch 7 in Australia is that it play then pauses Plays the pauses ect ect .. If I can manage to pause the Live TV feed for 3 to 4 secs the buffer is nearly 50% and all is fine .. Its as if the playback is happening to quick and needs a bit more time for media center backend to cache the live feed.. Now the funny thing is that HD channels are not affected even thou the data rate is about 7-9mpbs and the SD feed is lucky if it is 3mbps
