Full Version: Upp one directory level
is there a single button press to go upp one direcory level?
for example, all my mp3's are stored in various folders.  one of these folders has 525 mp3's in it.  if i happen to have been playing an mp3 half way down the file list in that folder and then want to go into another folder to play a different one in located in a differnet folder, i have to scroll through over 250 files to get to the top of the list to exit to the previous directoy level.  i use the xbox dvd remote when using xbmc and if one of the buttons could be mapped to allow me move upp one level in the directory tree it would make things much easier.
(roadrash @ april 05 2004,22:08 Wrote: i use the xbox dvd remote when using xbmc and if one of the buttons could be mapped to allow me move upp one level in the directory tree
in later xbmc cvs the "back" button is already mapped to that, but know that you can edit this yourself as you like in keymap.xml
