Full Version: Conditional Visibility for Image Control
I'd like to have a conditional visibility for an image control. The texture for the image control is:
PHP Code:
<texture>$INFO[ListItem.MPAA,flags/mpaa/,.png]</texture
The visibility condition I'd like to use is to check whether the file exists or not. I've tried using IsEmpty but have had no luck. How can I achieve this, if at all possible?
give the image control id, then use some dummy fallback and check against it.
<texture fallback="empty.jpg">$INFO[ListItem.MPAA,flags/mpaa/,.png]</texture>
then:
StringCompare(Control.GetLabel(id),empty.jpg)
Thanks tomer, that's a neat idea Smile I'll try this out later today and let you know how I get on. Thanks once again.
Just tested out Tomer's code, it works but it constantly flickers a few hundred times a second jumping position from it being visible to not being visible. Undecided I am using this within a grouplist control.
Here's the code that I'm using:
PHP Code:
                                <control type="image" id="1212">
width>90</width>
aspectratio>keep</aspectratio>
visible>!StringCompare(Control.GetLabel(1212),empty.jpg)</visible>
control
Would appreciate any help. Thanks
Actually the <visible> tag is for another control, to check if the image is actual "flag" or just "empty".
in the image control itself, you don't need this condition. (if not available, it won't show..)
what are you trying to achieve?
Thanks for getting back. Basically, I have an image control within a grouplist. I'd like the text to shift to the left and not leave a blank space for the image when the image (MPAA rating flag) file is not available.
Here is how it currently shows when the flag image is not available:
As you can see, there is a gap left where the image control should be. Undecided
Tried putting it in a group?
PHP Code:
<control type="group">
width>90</width>
width>90</width>
control>
control
(2016-02-21, 12:55)Hitcher Wrote: [ -> ]Tried putting it in a group?
PHP Code:
width>90</width>
width>90</width>
control>
control
Works perfect Hitcher. Never thought about putting it in a group. Already got too many group and grouplist controls lol but hey, another group won't hurt as long as it works.
Thank you so much Hitcher and Tomer Big GrinBig GrinBig Grin
