Full Version: Play SRF Addon
Hi there,
I developed an addon that gives you access to the Play SRF (http://www.srf.ch/play/tv) provided by Schweizer Fernsehen, the swiss television institution.
More details including the addon for my repository are available here:
http://www.mindmade.org/kodi.php
Code is hosted on gitub:
https://github.com/skandi/kodi-addon-srfplay
Any comments or feedback is welcome.
Cheers,
skandi
Great stuff, thanks a lot!
Thank you skandi. Good work, as always.
Thank you for developing this plugin. I just installed the plugin from the repository and I am noticing a weird behavior. Whenever I click an item to play the loading circle appears. And afer a while it exits and does nothing. I I click on the same item the second time video starts to play and i can hear the sound, but over the video there is a modal message box saying that this item in not playable. Whenever I click OK the box disappears, but also the playback exits, so I am not able to watch the video. This happened with every item that I tried to watch. I get the error in the log, but I can see that the video is actually playing.
ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.srfplay/?command=play&id=cc0a94cc-0dcf-46b6-bfa8-56ec5e528d96&title=Asche+auf+dein+Haupt]
Any ideas?
