I was given an android box and it worked well for about a week, it now says that it needs to be updated to 15.2 Isengard, I have tried to do this and get as far as bringing up the links in Google, but then when I click on them nothing downloads and nothing happens - can anyone please tell me what I am doing wrong?
Thanks for the info but northing happened with this link either?
It's working fine for me. It's probably getting a lot of traffic itself though, so keep trying on it.
you'll need to then go to the Android folder, then whichever version you need (arm for Amazon sticks for example) and then grab the apk file of the version you want (15.2 Isengard is the current stable, 16rc3 is the release candidate Jarvis) and sideload that.
Thanks for the information again, I am wondering if there could be a problem with this box as nothing is happening once I get to android? I have downloaded Kodi onto my pc successfully so the site would appear to be working?
I have now been able to get as far as the Android Arm, but once I click this nothing is downloading - is this just because of high demand, or am I doing something wrong?
I also have a fire tv box and have been trying to sideload Jarvis 16 using es explorer and not able to download to new version.
I get this error - The webpage at
http://mirrors.kodi.tv/releases/android/...bi-v7a.apk could not be loaded because net::ERR_EMPTY_RESPONSE.
I also tried going to
http://mirrors.kodi.tv/releases/ with no luck.
Does anyone know what this means and how I can fix this?
One more note...My box was auto updated with the current amazon update.
Hello everyone....new guy here...with a Wetek core...only using the android side at the moment, but on the upgrade to Jarvis, I am going to wait till this download gets sorted out. I am getting the same responce the website are not working or error
Having the same issue on fire tv trying to update using ES Explorer today. I have two of these boxes and I was able to update one of them late last night quite easily, although it did take a couple tries until the download actually started. When I tried to update the other box today using the same method I got a 502 error on the ES Explorer browser after cliking on the Android apk ARM link. Hope it's a temporary thing.
(2016-02-21, 19:19)Dig_it Wrote: [ -> ]Hello everyone....new guy here...with a Wetek core...only using the android side at the moment, but on the upgrade to Jarvis, I am going to wait till this download gets sorted out. I am getting the same responce the website are not working or error
There is a Wetek Core specific build of Kodi available, with some tweaks for the Core, I believe its based on Jarvis.
I'm having a problem installing Jarvis on one of my fire sticks also, with ES file explorer, when I click on ARM at the Kodi.tv downloads it wont' install. I installed this on my other stick hours before successfully. I also upgraded last month with Isengard on both stick successfully.
I don't get any error codes, it just spins for a second then stops.
Is the download site down, or is there something I can do?
Nothing worksfor for me on mx2box sincekodi6 update
