Does this support fullscreen/windowed toggle. Doesn't work for me. Any chance you'll be adding smart playlists as a separate view like tv and movies? Thanks
You should be able to toggle between windowed and full screen mode by tapping and holding the fullscreen button in the remote control view. About the second question should be something that in general should allow the main menu editing. It will need some work.
(2016-02-19, 11:18)joethefox Wrote: [ -> ]You should be able to toggle between windowed and full screen mode by tapping and holding the fullscreen button in the remote control view. About the second question should be something that in general should allow the main menu editing. It will need some work.
Thanks. Didn't know about the tap and hold. Works great! And thanks for looking into smart playlists.
(2016-02-19, 15:44)bobrap Wrote: [ -> ] (2016-02-19, 11:18)joethefox Wrote: [ -> ]You should be able to toggle between windowed and full screen mode by tapping and holding the fullscreen button in the remote control view. About the second question should be something that in general should allow the main menu editing. It will need some work.
Any update on the Smart playlists? Thanks.
