2016-02-18, 13:59
Desperate for some technical help
Gone to reset up my i3 nuc running openelec this morning. Like to reset it couple times a year etc
Anyway having reinstalled latest stable openelec I went to add my movies. I get an error message that it's unable to connect to remote server
I can add tv shows fine but not movies
So thought it must be a scraper issue so went to install my addons and perhaps get another scraper
However every single repo I add is empty, no matter the repo and no matter the number of refreshes I do, they are all empty
Any ideas ?
No amount of manually refreshing the repos etc will work. Even the stock Kodi repo is empty.
It's as if not connected to Internet but it's scraping tv shows fine just not scraping movies or finding anything in any repo
Any ideas ?
