first time using kodi, installed ok and downloaded apps but nothing will play. Keep getting error message about checking log files.
did a drbug and log file is here
http://xbmclogs.com/pyf7udj2k if anyone can tell me why its failing and how to fix it I would be very grateful
Is it just with the CBC add-on?
If so, you may be better asking in
the add-ons thread as you'll get more specific support there.
If not, please be a bit clearer and more specific about what the problem actually is, and with which add-on(s).
I get this error "One or more items failed to play. Check the log file for details" when I try to watch anything on any add on I have installed, EG CBC, MBC, ESPN3 etc.
I have only installed Kodi tonight so may be a simple setting
Can your stick connect to the internet at all via any other app? Just as a basic sanity check before getting too deep in anything.
Also can you try a generic video add-on like the YouTube one to confirm it's not an issue with geolocking or anything like that?
when I load youtube and after I have signed in, when I go to browse i get an error Exception in ContentProvider Unknown Kind "
It was connected to internet as it downloaded kodi from it
Been working and youtube'ing on it all day. Same thing sith the fire stick. Found any solutions?
