2016-02-19, 13:49
Hi all,
After installing Conq on my kodi 15.2 (which is amazing btw) and creating my own build, I am facing only 1 issue with the skin which is the General background in settings.
It comes on top of the background per addon / menu in the home screen.
Is there anyway to reset it so it will be off?
Another question, does the background feature in the skin supports PNG files in terms of transparent wallpapers - since JPG format doesn't.
regards,
regards,
