2016-02-21, 10:57
I'm using 16.0 final on my Shield with an Onkyo TX-NR626 receiver.
Is it a known issue that if you enable passthrough and possible also because of stereo upmix and try to change volume with the Shield remote it makes this horrible noise? If you do the same with Netflix (and the source is 5.1), you just get a notification that you need to change the volume on the receiver instead.
Video with the noise: https://goo.gl/photos/oN7jE69FeuixKnfz6
http://xbmclogs.com/p83l5rosn
