Full Version: Android TV UI sounds
Hopefully this is a good place to post this. I just wanted to share that I created a simple GUI Sounds addon for my Nexus Player. I know there's already an Android TV sounds addon in Kodi's repo, but it doesn't use the right sounds for at least the Nexus. I figured it's probably not the right sounds for other devices as well.
You can get it from my github. Check it out if you like. The only thing wrong with it is that the sounds are louder than in Kodi than outside of it.
https://github.com/shihrer/resource.uiso...ndroidtvui
Hi, the ones in the repo are copied from the master branch at https://android.googlesource.com/. They are for sure the ones used on the nvidia shield at least. Perhaps the nexus uses some custom ones? If you have the proper source with a license for these you should submit to the repo (probably under a different name though). There's room for both!
