Full Version: pvr.mythtv cut list versus commercial flags
I have the the latest updates on my mythtv-backend and when I play recorded TV via Kodi 15.2/pvr-mythtv 2.8.4, I get the commercial skips, but if I edit the recording to adjust the commercial skips to correct problems, those edits saved to the cut-list don't have any affect on the playback. I use mythtv-frontend to edit the recorded TV. Playing the recording with mythtv frontend does show the correct commercial cuts from the edit.
To edit the recorded TV, I load the flagged commercials, move the cuts around, then save the edits as a cut-list.
Is there a way to use Kodi pvr.mythtv to play a recorded TV that has a cut-list?
