In addon IGN.com, when i add to favorites category ''Latest videos" or any other and then when in this category are new videos, when category open from the favorites, the new videos are not displayed,
it shows only those videos that were at the time of adding to favorites.
But if I open a category directly from add-on all ok.
The same thing with CBSnews.com and perhaps with all the others.
Fire TV Kodi v16 Final
Galaxy s5 and ipad mini 2 have the same problem.
Is there support here or pointless to write about the problems?
Not sure, but I've seen the same thing when using favorites and the YouTube add-on (when it worked). I don't know if it's specific to the add-on or if a link from favorites doesn't refresh the listing.
I think a link from favorites doesn't refresh the listing, how to fix it or should i stay on 15?
Please test this problem someone?
In folder Temp kodi create files with the extension ".fi" when i remove them, addon folder open all last video
But then kodi create this files again, and addon folder open this cache and not realtime addon directory
In kodi 14 and 15 kodi don't create this files
Kodi 16 rc2
How to do that Kodi did not create these files?
When i open videoaddon directory shortcut from favorites or widgets, in first opening Kodi create the cache files addon directory in userdata/temp folder and next time is always open the cache files and there its no new update video.
Kodi 16.1rc2 AFTV, Galaxy S6, Ipad mini 2
This proplem easy to check, please help me fix this issue
Two mounths i am asking for help and no help here..
Kodi 16.1 final problem still there
Great...maybe file a ticket on the trac website?
http://trac.kodi.tv/ might get more traction
Sent from my Nexus 5
When i open directory from favorites in the log doesn't have this line:
22:08:15 T:18446744072507958752 DEBUG: Clearing cached fileitems
But if i open directly from add-on this line is in the log and all new video
Favorites and other shortcuts don't force a recache. What you can do to workaround the problem is to delete the cache manually. It might make sense to always force a recache if the path is an url. I'll have a look at that.
