2016-02-23, 18:13
I've been dealing with this problem for over a month on 2 different systems, I've deleted most of the addons and all but three repository's (Kodi Repository and Repo VC (Voxcommando Repo) Lunatixz Repo) and I have come to find out that it is happening when its checking for updates,
I've searched the forums and haven't found anything that seems to fix the problem
Both systems are windows 8.1 but have different specs
Main System Log: http://pastebin.com/V3vwuNRt
2nd System Log: http://pastebin.com/7bqjH0dK
removing Repo on 2nd system Log: http://pastebin.com/6WZHSGSn
and just in case here's a copy of my advanced settings
From what I found none of my advanced settings should be causing the problem but I saw on another thread where a cache setting did cause it, so I thought I better cover all bases
Also I have to go into my addons are no longer updating automatically, I'm assuming its because of the crashes
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.110</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<videolibrary>
<importwatchedstate>true</importwatchedstate>
<importresumepoint>true</importresumepoint>
<cleanonupdate>true</cleanonupdate>
</videolibrary>
<video>
<timeseekbackward>-7</timeseekbackward>
</video>
<pathsubstitution>
<substitute>
<from>special://profile/playlists/</from>
<to>SMB://MAIN-XBMC/Users/sallyj/AppData/Roaming/Kodi/userdata/playlists/</to>
</substitute>
</pathsubstitution>
</advancedsettings>
