Full Version: -SOLVED- Kodi 16 on Mac / TVHeadend 4.0.8 / Live TV HD-Channels not usable
just upgraded Kodi from 15.2. to 16.0. Everything is working fine, but trying to watch HD-Channel from LiveTV (with TVHeadend) just shows the Cache-Progress-Bar standing with 0% all the time. Pressing "Stop" returns to Channel Selection. Watching SD-Channels is no Problem.
Following Kodi-Debug-Log, when i tried to watch a HD-Channel (German ARD HD).
Any help appreciated.
Regards
LuckyLuis
Quote:17:47:42 T:140735233298432 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:47:42 T:140735233298432 NOTICE: -----------------------------------------------------------------------
17:47:42 T:140735233298432 NOTICE: Starting Kodi (16.0 Git:2016-02-20-a5f3a99). Platform: OS X x86 64-bit
17:47:42 T:140735233298432 NOTICE: Using Release Kodi x64 build
17:47:42 T:140735233298432 NOTICE: Kodi compiled Feb 20 2016 by Clang 6.0 (clang-600.0.56) for OS X x86 64-bit version 10.7.0 (1070)
17:47:42 T:140735233298432 NOTICE: Running on Apple Inc. Macmini6,1 with OS X 10.11.3, kernel: Darwin x86 64-bit version 15.3.0
17:47:42 T:140735233298432 NOTICE: Host CPU: Intel® Core™ i5-3210M CPU @ 2.50GHz, 4 cores available
17:47:42 T:140735233298432 NOTICE: special://xbmc/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
17:47:42 T:140735233298432 NOTICE: special://xbmcbin/ is mapped to: /Applications/Kodi.app/Contents/Resources/Kodi
17:47:42 T:140735233298432 NOTICE: special://masterprofile/ is mapped to: /Users/andreas/Library/Application Support/Kodi/userdata
17:47:42 T:140735233298432 NOTICE: special://home/ is mapped to: /Users/andreas/Library/Application Support/Kodi
17:47:42 T:140735233298432 NOTICE: special://temp/ is mapped to: /Users/andreas/.kodi/temp
17:47:42 T:140735233298432 NOTICE: special://frameworks/ is mapped to: /Applications/Kodi.app/Contents/Libraries
17:47:42 T:140735233298432 NOTICE: The executable running is: /Applications/Kodi.app/Contents/MacOS/Kodi
17:47:42 T:140735233298432 NOTICE: Local hostname: macmini.fritz.box
17:47:42 T:140735233298432 NOTICE: Log File is located: /Users/andreas/Library/Logs/kodi.log
17:47:42 T:140735233298432 NOTICE: load settings...
17:47:42 T:140735233298432 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
17:47:42 T:140735233298432 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
17:47:42 T:140735233298432 NOTICE: Found 1 Lists of Devices
17:47:42 T:140735233298432 NOTICE: Enumerated DARWINOSX devices:
17:47:42 T:140735233298432 NOTICE: Device 1
17:47:42 T:140735233298432 NOTICE: m_deviceName : default
17:47:42 T:140735233298432 NOTICE: m_displayName : Default
17:47:42 T:140735233298432 NOTICE: m_displayNameExtra: Built-in Output
17:47:42 T:140735233298432 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
17:47:42 T:140735233298432 NOTICE: m_channels : FL,FR
17:47:42 T:140735233298432 NOTICE: m_sampleRates : 96000,88200,48000,44100,32000
17:47:42 T:140735233298432 NOTICE: m_dataFormats : AE_FMT_S24LE3,AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_FLOAT
17:47:42 T:140735233298432 NOTICE: Device 2
17:47:42 T:140735233298432 NOTICE: m_deviceName : Built-in OutputConfusedtream0
17:47:42 T:140735233298432 NOTICE: m_displayName : Built-in Output
17:47:42 T:140735233298432 NOTICE: m_displayNameExtra: Digital Out
17:47:42 T:140735233298432 NOTICE: Device 3
17:47:42 T:140735233298432 NOTICE: m_deviceName : HDMIConfusedtream0
17:47:42 T:140735233298432 NOTICE: m_displayName : HDMI
17:47:42 T:140735233298432 NOTICE: m_displayNameExtra: SAMSUNG
17:47:42 T:140735233298432 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
17:47:42 T:140735233298432 NOTICE: m_sampleRates : 48000,44100,32000
17:47:42 T:140735233298432 NOTICE: m_dataFormats : AE_FMT_S24LE3,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_S16LE
17:47:42 T:140735233298432 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
17:47:42 T:140735233298432 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
17:47:42 T:140735233298432 NOTICE: Default DVD Player: dvdplayer
17:47:42 T:140735233298432 NOTICE: Default Video Player: dvdplayer
17:47:42 T:140735233298432 NOTICE: Default Audio Player: paplayer
17:47:42 T:140735233298432 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:47:42 T:140735233298432 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:47:42 T:140735233298432 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
17:47:42 T:140735233298432 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
17:47:42 T:140735233298432 NOTICE: Loaded playercorefactory configuration
17:47:42 T:140735233298432 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
17:47:42 T:140735233298432 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
17:47:42 T:123145308282880 NOTICE: virtual bool CAESinkDARWINOSX::Initialize(AEAudioFormat &, std:Confusedtring &): Opening default device Built-in Output
17:47:42 T:140735233298432 NOTICE: Running database version Addons20
17:47:42 T:140735233298432 NOTICE: ADDONS: Using repository repository.xbmc.org
17:47:42 T:140735233298432 NOTICE: Setup SDL
17:47:42 T:140735233298432 NOTICE: Display 0 has name SAMSUNG
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1360 x 768 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 50.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1280 x 720 @ 50.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 720 x 480 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 720 x 576 @ 50.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 24.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 25.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1920 x 1080 @ 30.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 640 x 480 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 800 x 600 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1024 x 768 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1024 x 576 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1280 x 960 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1344 x 1008 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Found possible resolution for display 0 with 1600 x 900 @ 60.000000 Hz
17:47:42 T:140735233298432 NOTICE: Checking resolution 16
17:47:42 T:140735233298432 NOTICE: GL_VENDOR = Intel Inc.
17:47:42 T:140735233298432 NOTICE: GL_RENDERER = Intel HD Graphics 4000 OpenGL Engine
17:47:42 T:140735233298432 NOTICE: GL_VERSION = 2.1 INTEL-10.12.13
17:47:42 T:140735233298432 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
17:47:42 T:140735233298432 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
17:47:42 T:140735233298432 NOTICE: Running database version ViewModes6
17:47:42 T:140735233298432 NOTICE: Running database version Textures13
17:47:42 T:140735233298432 NOTICE: Running database version MyMusic56
17:47:42 T:140735233298432 NOTICE: Running database version MyVideos99
17:47:42 T:140735233298432 NOTICE: Running database version TV29
17:47:42 T:140735233298432 NOTICE: Running database version Epg11
17:47:42 T:140735233298432 NOTICE: start dvd mediatype detection
17:47:43 T:140735233298432 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:47:43 T:140735233298432 NOTICE: ActiveAE DSP - starting
17:47:43 T:140735233298432 NOTICE: UpdateLibraries: Starting video library startup scan
17:47:43 T:123145311043584 NOTICE: PVRManager - starting up
17:47:43 T:140735233298432 NOTICE: initialize done
17:47:43 T:140735233298432 NOTICE: Running the application...
17:47:43 T:123145311580160 NOTICE: VideoInfoScanner: Starting scan ..
17:47:43 T:140735233298432 NOTICE: starting zeroconf publishing
17:47:43 T:140735233298432 NOTICE: WebServer: Started the webserver
17:47:43 T:140735233298432 NOTICE: starting upnp client
17:47:43 T:140735233298432 NOTICE: starting upnp server
17:47:43 T:140735233298432 NOTICE: starting upnp renderer
17:47:43 T:123145323384832 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
17:47:43 T:123145323384832 NOTICE: UDP: Listening on port 9777
17:47:45 T:123145311580160 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:02
17:47:55 T:140735233298432 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
17:47:55 T:140735233298432 NOTICE: Enabled debug logging due to GUI setting. Level 2.
17:47:55 T:140735233298432 DEBUG: ------ Window Init () ------
17:47:58 T:140735233298432 INFO: Python, unloading python shared library because no scripts are running anymore
17:47:58 T:140735233298432 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
17:47:58 T:140735233298432 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
17:47:58 T:140735233298432 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
17:47:58 T:140735233298432 DEBUG: ------ Window Init (Settings.xml) ------
17:47:59 T:140735233298432 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
17:47:59 T:140735233298432 DEBUG: ------ Window Deinit (Settings.xml) ------
17:47:59 T:140735233298432 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
17:47:59 T:140735233298432 DEBUG: ------ Window Init (Home.xml) ------
17:48:02 T:140735233298432 DEBUG: Activating window ID: 10615
17:48:02 T:140735233298432 DEBUG: ------ Window Deinit (Home.xml) ------
17:48:02 T:140735233298432 DEBUG: ------ Window Init (MyPVRChannels.xml) ------
17:48:02 T:140735233298432 INFO: Loading skin file: MyPVRChannels.xml, load type: KEEP_IN_MEMORY
17:48:02 T:140735233298432 DEBUG: CGUIMediaWindow::GetDirectory (pvr://channels/tv/Alle Kanäle/)
17:48:02 T:140735233298432 DEBUG: ParentPath = []
17:48:02 T:140735233298432 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/Alle Kanäle)
17:48:04 T:140735233298432 DEBUG: Loading settings for pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers(pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr)
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
17:48:04 T:140735233298432 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
17:48:04 T:140735233298432 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
17:48:04 T:140735233298432 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData
17:48:04 T:140735233298432 NOTICE: DVDPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr
17:48:04 T:140735233298432 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
17:48:04 T:140735233298432 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
17:48:04 T:140735233298432 DEBUG: LinuxRendererGL: Cleaning up GL resources
17:48:04 T:140735233298432 DEBUG: CLinuxRendererGL:TonguereInit - precision of luminance 16 is 16
17:48:04 T:123145303453696 DEBUG: Thread DVDPlayer start, auto delete: false
17:48:04 T:123145303453696 NOTICE: Creating InputStream
17:48:04 T:123145303453696 DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'Das Erste HD'
17:48:04 T:123145303453696 DEBUG: opening live stream for channel 'Das Erste HD'
17:48:04 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux open
17:48:04 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux subscribe to 1360759355
17:48:04 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux successfully subscribed to channel id 1360759355, subscription id 1
17:48:04 T:123145303453696 DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr
17:48:04 T:123145303453696 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr
17:48:04 T:123145303453696 NOTICE: Creating Demuxer
17:48:04 T:123145303453696 ERROR: Get - failed to get stream
17:48:04 T:123145303453696 DEBUG: CDVDPlayer::SetCaching - caching state 2
17:48:04 T:123145303453696 WARNING: CDVDMessageQueue(audio):Tongueut MSGQ_NOT_INITIALIZED
17:48:04 T:123145303453696 WARNING: CDVDMessageQueue(video):Tongueut MSGQ_NOT_INITIALIZED
17:48:04 T:123145303453696 DEBUG: OnPlayBackStarted: play state was 1, starting 1
17:48:04 T:140735233298432 DEBUG: PlayFile: OpenFile succeed, play state 2
17:48:04 T:140735233298432 DEBUG: OnPlayBackStarted: play state was 2, starting 0
17:48:04 T:140735233298432 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
17:48:04 T:123145314263040 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unhandled subscription message [subscriptionGrace]
17:48:04 T:140735233298432 DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr)
17:48:04 T:140735233298432 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
17:48:04 T:140735233298432 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
17:48:04 T:140735233298432 DEBUG: UPnP: Building didl for object 'pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr'
17:48:04 T:140735233298432 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - Announce(flag=Player, sender=xbmc, message=OnPlay)
17:48:14 T:140735233298432 INFO: CheckIdle - Closing session to http://api.tmdb.org (easy=0x7fe6ba130400, multi=0x7fe6beb11230)
17:48:15 T:123145314263040 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unhandled subscription message [subscriptionGrace]
17:48:17 T:140735233298432 NOTICE: CDVDPlayer::CloseFile()
17:48:17 T:140735233298432 NOTICE: DVDPlayer: waiting for threads to exit
17:48:18 T:123145303453696 NOTICE: CDVDPlayer::OnExit()
17:48:18 T:123145303453696 DEBUG: CDVDPlayer::SetCaching - caching state 0
17:48:18 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unsubscribe from 1360759355
17:48:18 T:123145311580160 DEBUG: DoWork - Saving file state for video item pvr://channels/tv/Alle Kanäle/pvr.hts_1360759355.pvr
17:48:18 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux successfully unsubscribed from channel id 1360759355, subscription id 1
17:48:18 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux close
17:48:18 T:123145303453696 DEBUG: CDVDInputStreamPVRManager::Close - stream closed
17:48:18 T:123145303453696 DEBUG: OnPlayBackStopped: play state was 2, starting 0
17:48:18 T:123145303453696 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
17:48:18 T:123145303453696 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
17:48:18 T:123145303453696 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - Announce(flag=Player, sender=xbmc, message=OnStop)
17:48:18 T:140735233298432 NOTICE: DVDPlayer: finished waiting
17:48:18 T:123145303453696 DEBUG: Thread DVDPlayer 123145303453696 terminating
17:48:18 T:140735233298432 DEBUG: LinuxRendererGL: Cleaning up GL resources
17:48:18 T:140735233298432 NOTICE: CDVDPlayer::CloseFile()
17:48:18 T:140735233298432 NOTICE: DVDPlayer: waiting for threads to exit
17:48:18 T:140735233298432 DEBUG: Radio UECP (RDS) Processor - delete ~CDVDRadioRDSData
17:48:18 T:140735233298432 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
17:48:21 T:140735233298432 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
17:48:21 T:140735233298432 DEBUG: ------ Window Deinit (MyPVRChannels.xml) ------
17:48:21 T:140735233298432 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
17:48:21 T:140735233298432 DEBUG: ------ Window Init (Home.xml) ------
17:48:23 T:140735233298432 DEBUG: Activating window ID: 10004
17:48:23 T:140735233298432 DEBUG: ------ Window Deinit (Home.xml) ------
17:48:23 T:140735233298432 DEBUG: ------ Window Init (Settings.xml) ------
17:48:25 T:140735233298432 DEBUG: Activating window ID: 10016
17:48:25 T:140735233298432 DEBUG: ------ Window Deinit (Settings.xml) ------
17:48:25 T:140735233298432 DEBUG: ------ Window Init (SettingsCategory.xml) ------
17:48:31 T:140735233298432 NOTICE: Disabled debug logging due to GUI setting. Level 0.
17:48:31 T:140735233298432 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
17:48:34 T:140735233298432 ERROR: Unable to activate the previous window
17:48:40 T:140735233298432 NOTICE: Storing total System Uptime
17:48:40 T:140735233298432 NOTICE: Saving settings
17:48:40 T:140735233298432 NOTICE: stop all
17:48:40 T:140735233298432 NOTICE: stop player
17:48:40 T:140735233298432 NOTICE: PVRManager - stopping
17:48:41 T:140735233298432 NOTICE: ES: Stopping event server
17:48:41 T:140735233298432 NOTICE: stopping upnp
17:48:42 T:140735233298432 NOTICE: stopping zeroconf publishing
17:48:42 T:140735233298432 NOTICE: WebServer: Stopped the webserver
17:48:42 T:123145323384832 NOTICE: ES: UDP Event server stopped
17:48:42 T:140735233298432 NOTICE: stop dvd detect media
17:48:42 T:140735233298432 NOTICE: stop sap announcement listener
17:48:42 T:140735233298432 NOTICE: clean cached files!
17:48:42 T:140735233298432 NOTICE: unload skin
17:48:43 T:140735233298432 NOTICE: stopped
17:48:43 T:140735233298432 NOTICE: destroy
17:48:43 T:140735233298432 NOTICE: closing down remote control service
17:48:43 T:140735233298432 NOTICE: unload sections
17:48:43 T:140735233298432 NOTICE: special://profile/ is mapped to: special://masterprofile/
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
17:48:43 T:140735233298432 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
17:48:43 T:140735233298432 NOTICE: application stopped...
Solved by myself: Turn of Default Setting for Hardware Accelleration in Video-Settings ....
I have exactly the same issue. I want to watch the new HD channels ARD and ZDF, which are free to air, but my Kodi is stuck when it starts to load the stream. I suppose it's because the new channels use the H.265 codec, which is actually perfectly supported by Kodi. I recorded a show and was able to watch the recorded show via Kodi.
But as soon as i want to stream live tv its stuck on loading the stream. SD channels still work fine.
Could you post me your settings you are using? I think i tried all combinations, but maybe i am missing something.
here is what i caught from my kodi.log:
23:05:55 T:140467955525632 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
23:05:55 T:140465152190208  NOTICE: Creating InputStream
23:05:55 T:140465152190208  NOTICE: Creating Demuxer
23:05:55 T:140465152190208   ERROR: Get - failed to get stream
23:05:55 T:140465152190208 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
23:05:55 T:140465152190208 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
My kodi version is 16.1 jarvis and runs on a Linux Mint 17.3 rosa. My tvheadend 4.08 is running on a Raspberry PI with debian jessie.
Can anyone provide help?
Thanks in advance
Hi
same problem here with TVH 4.0.8 on a Raspberry and KODI 16.1 on Windows10 or LibreElec 7.0.1 on a O-Droid C2
regards
Ralatick
Hello both mdawid and ralatick, i'm the third here: same log and same problem of yours but only for one channel. This channel strangely has also no service name? and when mapped it doesn't work. Are all channel not working for you?
For me all FTA HD Channels ( just 2 in the moment )
(2016-06-17, 09:26)ralatick Wrote: [ -> ]For me all FTA HD Channels ( just 2 in the moment )
There must be something, for me it's a "new" channel that works with web interface and also with vlc but no with kodi( htsp) . 2 questions, let's try what we have in common Wink, have your not working channels a "service name" mine no, and so it's mapped with no name, what is also your service Id ? Mine 0 were it should be 1 or 0x19 ( Click edit on that channel on service list , than "read only information" service Id) these are the only two strange things that I've found
(2016-06-17, 11:03)anthonytex Wrote: [ -> ]
yes they have a service name ( ZDF HD / Das Erste HD ) and id ( 16961 / 769 )
(2016-06-17, 21:58)ralatick Wrote: [ -> ]
i've respond to you in the other thread Wink
