2016-02-24, 22:23
After updating to Jarvis on Arch Linux my Kodi is completely broken and unusable. Log shows:
"ERROR: Unable to open database: MyMusic56 [1049](Unknown database 'MyMusic56')"
...... all the way down to ...............
"ERROR: Unable to open database: MyMusic32 [1049](Unknown database 'MyMusic32')".
Same goes for video database.
This is after I dropped old databases and let kodi create a new one.
Some more relevant stuff from the log:
Seems to be a syntax error from the code but I don't see anything obvious. I any case I don't believe it's something I can fix on my end.
ERROR: SQL: [MyVideos99] Undefined MySQL error: Code (1064)
Query: CREATE VIEW tvshow_view AS SELECT tvshow.*, path.idParentPath AS idParentPath, path.strPath AS strPath, tvshowcounts.dateAdded AS dateAdded, lastPlayed, totalCount, watchedcount, totalSeasons FROM tvshow LEFT JOIN tvshowlinkpath ON tvshowlinkpath.idShow=tvshow.idShow LEFT JOIN path ON path.idPath=tvshowlinkpath.idPath INNER JOIN tvshowcounts ON tvshow.idShow = tvshowcounts.idShow GROUP BY tvshow.idShow
20:06:57 T:139636806830208 ERROR: CreateDatabase unable to create database:2
20:06:57 T:139636806830208 NOTICE: Running database version TV29
20:06:57 T:139636806830208 NOTICE: Running database version Epg11
20:06:57 T:139636806830208 NOTICE: start dvd mediatype detection
20:06:58 T:139636806830208 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:06:58 T:139636806830208 NOTICE: ActiveAE DSP - starting
20:06:58 T:139636806830208 NOTICE: UpdateLibraries: Starting video library startup scan
20:06:58 T:139636806830208 NOTICE: initialize done
20:06:58 T:139636806830208 NOTICE: Running the application...
20:06:58 T:139635812116224 NOTICE: script.grab.fanart: Grab Fanart Service Started
20:06:58 T:139636806830208 ERROR: SQL: [MyVideos99] The table does not exist
Query: SELECT movie_view.idSet,COUNT(1) AS c FROM movie_view JOIN sets ON sets.idSet = movie_view.idSet GROUP BY movie_view.idSet HAVING c>1
20:06:58 T:139636806830208 ERROR: HasSets failed
20:06:58 T:139636806830208 NOTICE: WebServer: Started the webserver
20:06:58 T:139636806830208 NOTICE: starting upnp client
20:06:58 T:139635191691008 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:06:58 T:139635191691008 NOTICE: UDP: Listening on port 9777
20:06:58 T:139636806830208 ERROR: JSONRPC Server: Failed to connect to sdpd
20:06:58 T:139635795068672 NOTICE: CleanDatabase: Starting videodatabase cleanup ..
20:06:58 T:139635812116224 ERROR: SQL: [MyVideos99] The table does not exist
Query: select * from movie_view
20:06:58 T:139635812116224 ERROR: GetMoviesByWhere failed
