Full Version: (SOLVED) Skin shortcuts Unable to build menu
Hello
I am using kodiubuntu
I have upgraded to Jarvis and Eminence 2.0 but when ever I come back to home screen
I got an error message "Skin shortcuts - Unable to build menu"
Here is my log file
http://goo.gl/jdA6T0
One or more of the files in which your menus are saved in are corrupt. Delete the folder userdata (wiki)/addon_data/script.skinshortcuts, or use any 'Reset main menu to default' or equivalent option in the skins settings.
Hey thank you very much Smile
Problem solved
(2016-02-25, 22:18)BobCratchett Wrote: [ -> ]One or more of the files in which your menus are saved in are corrupt. Delete the folder userdata (wiki)/addon_data/script.skinshortcuts, or use any 'Reset main menu to default' or equivalent option in the skins settings.
- wrong thread -
