Finally got it working:
Google Maps and Geocoder on your XBOX!
Just enter an address with the virtual keyboard
and see the adress location pop up on your screen.
You can even pan left/right/up/down and zoom in/out.
Download it here:
http://www.mobilebenefits.nl/XBMC/LocatU.zip
Unpack it and copy the folder LocatU to your scripts directory.
Hope you like it.
Asteronimo
I guess I should be flattered?
Good stuff! I'll try tonight!!
Does anybody got an screen sample of this?
I am also working on an implementation of the Google route-mapping feature.
This will take me at least another 3 weeks though.
Asteronimo
good script man, i had a look last night!!!!!
Thnx!
I had some bad luck, my xbox is dead
So I have to mod another with an Xeno FX chip I have lying around
before I can continue coding.
Well, gives me a chance to try the xbox emulator on my pc.
Cool stuff?, ...has you submitted the script(s) to
XBMCscripts.com yet
(so that it/they can easily be downloaded by everyone via their script)
Yes, it's also in the XBMCScripts list.
I will be posting regular updates like:
- show nearby businesses
- distance measuring between 2 locations
- uploading and showing itineraries (mountain trips, etc.)
Let me know what else you would like to see.
asteronimo Wrote:Let me know what else you would like to see.
will it ever be possible to switch between the regular map-view, and the satellite or hybrid one? I wanna see my house on my xbox
Yes, switching between regular map and satellite images will be possible in a few weeks.
Hybrid may not be possible because it uses a lot of AJAX technology which is difficult to port to a scripting language like Python.
As you may know,
LocatU is the Google Maps interface for the XBOX.
v1.1 was released a few weeks ago and I am happy to announce that v1.2
is now ready to be released.
v.1.2 has satellite maps added.
You can download it with XBMCScripts in a couple of days.
Have fun with it!
v1.2 with satellite maps added, will be released thru XBMCScripts in a couple of days.
Nice script,
a suggestion, if your going to use getButtonCode(), then add the codes for a remote and keyboard also.
eg MOVEMENT_UP = ( 166, 270, 61478, )
Thnx, I wasn't aware they were different.
I will implement them in the next release (v1.3).
