2016-02-27, 14:15
Hi guys,
Just a quick question, I need a texture location to be formatted using a VAR. It should be in the format: flags/mpaa/[VAR].png
Would this work?
I'm not able to test it at the moment, so would appreciate if someone can tell if the formatting is correct.
Would this work?
PHP Code:
<texture fallback="empty.jpg">$VAR[GetShortenedMPAA,flags/mpaa/,.png]</texture>
