2016-02-28, 09:43
Hello.
(I ask my question beforehand, so that you can skip the explaination below, if it does not apply to you)
Can we please have a Flag that allows us to choose to skip the default viewing mode and start directory based by default?
That's it, now the story behind this request. Over the years I collected a fairly huge amount of series. Most of it is scrapeable, but some is to old or to exotic to be labeled by a scrapper. Actually I have almost 200 directories in my series directory that are unscrapeable.
Now the problem: Whenever I start Kodi and select 'series', I end in the series directory, but only with scraping credentials. That means, I don't see the unscrapeable content (using banner view).
To circumvent this I then move to the beginning of that list and press the 'up' button, again 'up'button' and end in the listbox that has the 'files' option in it. I select this and go back to the series-directory from there.
_Then_ is the first time I see the complete list of series-directories there. The unscraped directories are then labeled with a default folder icon, which is sufficient at this point!
To get over this situation I'd put a default thumbnail into these directories, which makes the system think, it belongs in the 'scraped list'. So next Time I opended kodi I would see this serie eventually.
However, it has some drawbacks. First of all it is an insane amount of stupid work to label all those unscrapeable dirs with a dummy thumbnail to circumvent that behaviour. But more important, whenever you rebuild the database, they're gone (which is technically correct). So same procedure all over again.
I have tried almost any option that has the faintest connection to this topic, but I have not found a solution and that led me here. Is there any help in sight? Thanks in advance.
Dizman
Dizman
