Full Version: Estouchy
Pages: 1 2 3 4 5 6
already changed the width of the scrollbars a week or two ago.
please make sure you're using the latest version of kodi (v17 alpha2)
(2016-07-04, 10:01)propergol Wrote: [ -> ]I love the simplicity of this skin.
One note : on Surface Pro 4 tablet, all the buttons look streched, not by a lot but maybe something like 10% higher than width.
Videos, photos are not affected, only interface.
I post this problem here but I have the exact same issue with Jarvis and Confluence.
Edit : the Surface Pro 4 has a resolution of 2736 x 1824 that's a 3:2 ratio
the skin is optimized for both 4:3 and 16:9 aspect ratios.
i don't see any streched buttons on my end when i test in 4:3.
perhaps you could provide a screenshot of the issue?
Would it be possible to include the settings "Show movie sets" also on the Movie setting dialog? I.e., on bottom right of Movie main screen.
This control groups movies by Set or by Title. Having it also available on the main frame, would allow a "non-techy" person - aka my-wife - access to both sort functions.
Dean
nope, it's not possible to put kodi settings in other windows.
I somehow managed to change to the estouchy skin on my Apple TV 4. Am I just stuck on this now? Any help will be greatly appreciated.
(2016-09-10, 20:35)TSG1899 Wrote: [ -> ]I somehow managed to change to the estouchy skin on my Apple TV 4.
could you tell me how you managed to do that?
it should not be possible to switch to estouchy without either a mouse or a touchscreen
and if there's a loophole somewhere i want to make sure it gets fixed.
(2016-09-10, 20:38)ronie Wrote: [ -> ]
I just installed the march update of kodi onto my Apple TV and as everything new you go through everything so of course I clicked on the Estouchy skin, it asked me if I wanted to keep the changes and I got to reject it and switch back to the Estuary skin but next time I opened kodi it was on the Estouchy skin somehow.
ok, thx! a bit odd ineed.
the reset kodi to it's defaults, you need to first quit kodi,
and then remove the guisettings.xml file in the userdata folder.
http://kodi.wiki/view/Userdata
(2016-09-10, 20:54)ronie Wrote: [ -> ]ok, thx! a bit odd ineed.
Will this remove all my current settings then?
(2016-09-10, 20:56)TSG1899 Wrote: [ -> ]
yup. if you want to keep those, you need to edit the file.
search the file for 'skin.estouchy' and change it to 'skin.estuary'.
(2016-09-10, 21:10)ronie Wrote: [ -> ]
Can't seem to figure out how I can get to the userdata folder on an Apple TV.
How can this skin be installed? I have Libreelec 8.0 alpha including Kodi Krypton beta, This skin is not available on the additional skin list.
My system is runnig on an RPi and I would like to add touch screen support. What I am looking for is a good skin optimized for small touch screen.
(2016-09-11, 13:24)sakos Wrote: [ -> ]Hi,
It should be there by default. If not ask Liberelec why they have not added it
Does this skin support shortcuts from addons on a homescreen?
nope, there's no support for it.
Pages: 1 2 3 4 5 6
