2016-02-29, 06:47
I now use the version
VERSION_MAJOR 17
VERSION_MINOR 0
VERSION_TAG ALPHA1
VERSION_CODE 169701
ADDON_API 16.9.701
I want to change the Kodi Android version of the package, such as modifying the package name "org.xbmc.abc" can give a comprehensive tutorial please.
What place to need to modify the normal execution?
At present, I modified the version.txt APP_NAME but after the success of the compiler to start the installation will appear after the wrong exit.
Thank you very much
VERSION_MAJOR 17
VERSION_MINOR 0
VERSION_TAG ALPHA1
VERSION_CODE 169701
ADDON_API 16.9.701
Thank you very much
