Full Version: Navigation bug in DialogSelect.xml
In the Jarvis version of Confluence there is a bug in the DialogSelect.xml when using the list control with ID 6 (rather than 3).
In this situation, if the Cancel button or Scroll Bar is navigated to using keyboard or remote, you can then only navigate between the scroll bar and cancel button, there is no way to then navigate to back to the list (obviously this isn't a problem with a mouse).
I would post on trac but I get this error when I try and login
Missing or invalid form token. Do you have cookies enabled?
Just to confirm Krypton/Estuary doesn't exhibit the same problem.
