I've been using PSTVL since the early days, but one thing I've never been able to figure out is what keyboard shortcuts I use to access the EPG, On Demand, Apps, and DVR buttons across the top. Can someone please help me out? '
Thanks,
Angel
(2016-02-29, 20:57)tromy Wrote: [ -> ]http://kodi.wiki/view/Add-on:Keymap_Editor
Go to "Global" then "Virtual Keyboard" and enable "Teletext Red" "Teletext Green" etc...
Thanks Tromy I have my remote programmed with event ghost, but I figured it out
(2016-03-01, 03:29)MrsAngelD Wrote: [ -> ] (2016-02-29, 20:57)tromy Wrote: [ -> ]http://kodi.wiki/view/Add-on:Keymap_Editor
Can you please share how you did this in EventGhost?
Thanks,
Jin
(2016-03-07, 17:34)JinNJuice Wrote: [ -> ] (2016-03-01, 03:29)MrsAngelD Wrote: [ -> ] (2016-02-29, 20:57)tromy Wrote: [ -> ]http://kodi.wiki/view/Add-on:Keymap_Editor
Thanks,
Jin
Sorry it took me so long to respond.
I just had Event Ghost open and then pushed the buttons so the commands showed up on the left hand side, then I drug the commands from the left side of event ghost to proper buttons on right side. It took a bit of messing around before I figured out which ones were the proper ones. But I finally found the right ones Labeled Red, Yellow, Green, and Blue under
XBMC2 -> Actions -> Uncategorized Actions
