Hello I'm trying to fix my kodi box. I go to skins to try and put it back on titan and when I click on it a box with a red X on the bottom right hand corner shows up and says some files are missing and titan won't work. How do I fix this. So I can watch my movies and tv shows. Please help
Are you talking about the titan skin?
Yes. It's not working for me.
Sounds like you posted on the wrong sub forum
Idk how to do this itsy first time I'm just trying to get some answers
I've moved the thread to the correct sub-forum.
(2016-03-01, 19:40)Martinezmonique Wrote: [ -> ]Hello I'm trying to fix my kodi box. I go to skins to try and put it back on titan and when I click on it a box with a red X on the bottom right hand corner shows up and says some files are missing and titan won't work. How do I fix this. So I can watch my movies and tv shows. Please help
What is the exact error you're seeing ? Maybe you can create a screenshot or photo ?
You can easily switch to a different skin...
Looks like Titan may have become corrupt. I would delete it from the filesystem and reinstall.
