Full Version: Bug reports
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
Hi. Great skin. Nice work. A couple of bugs I have found.
In TV timers, it always seems to use the date format mm/dd/yyyy, although I have it set to UK 12 h (so dd/mm/yyyy).
Also in TV timers, the 'ascending/descending' order in the side menu doesn't do anything.
Finally, the TV EPG screen looks great, but navigating in this screen for a short time always seems to hang Kodi. I don't have logs right now, but can upload later if needed.
Best wishes,
Mark
I found little bug. Many buttons in Estuary dont have label (ex. Favourites on Home). Parameter $INFO[System.CurrentControl] shows "( )" on external lcd with lcdproc script.
In music the Song Information dialog could do with a tweek. It is not showing some of the basic data derrived from scanning tags e.g. artist name(s), album title, year etc. Once extra metadata has been scrapped e.g. biogs etc. that is shown.
At first I thought the track, title, year and artists were missing but now I see they were burried under my debug info text!
Missing album name, mood and comment text. Contributors list is flowing out the box (Confluence as an issue too, in needs to scroll perhaps).
Times played and last time played could be usefully added.
Album Information Dialog also needs a tweek.
Moods, styles, themes, and label are missing.
If album review text exists (not in image) then it is shown with title "Contributors"
That duration must be a song value, visible/left over if approached from Song Info dialog. Not sure that total time is available.
The genre is also the song genre, visible/left over if approached from Song Info dialog, not the album genre (can be different).
Times played and date last played could be useful additions too.
Music Artist Information dialog has missing data : styles, instruments and the various dates - born/formed, died/disbanded (that are not always just a date but may have place too)
Any way that the biography area could show the text the does not fit in the area rather than truncate? Arrow to page down perhaps like with the discography?
the new skin was not part works display Cyrillic characters, such as EPG, and information for your system.
on the old screen is all right.screenshots below:
Not sure if it's just me, but using file mode with viewtype list, the filenames don't autoscroll, unless they are in a subfolder
I'm not sure if it's a bug or just something still on your to-do list, but a heads-up: there's no "in progress" indication in the movie list for those movies you started watching any longer. Especially since this is getting more focus on the home screen now, I think it needs to be made clear in the list as well.
A need for people to be able to reset the "in progress" status from the context menu will increase now for the same reason, I expect.
@phil65
Not sure if your interested in outside input.
But I did a bit of editing in the pvr section of the skin so that it supports 4 digit channel names.
I can supply the edited files or just the changes made if your interested.
Installed the latest nightly build (KodiSetup-20160307-c6b201a-win32_installer.exe) on minimal, and when I run KODI I get the following pop-up error: "Uh oh, can't load sqlite3.dll, exiting".
ps. The error window name is "XMBC: Fatal Error", which needs a rename Wink
When installing the same build on "Full", KODI starts up normally. So I think that sqlite3.dll needs to be put into the core KODI package.
After getting it up and running, I noticed that the "Pictures" menu on the homescreen, does not contain a button to remove the menu item. This needs to be added.
Two minor bugs.
- Under skin settings|general, the "Choose Image Path" entry is greyed out while "Use custom global background" is enabled. Should be the opposite behavior.
- After installing an addon on a fresh Kodi install, it did not show up in the Addons main-menu item until I restarted Kodi. Not sure if that's a technical limitation or a skin/widget bug, but it did throw me off for a minute.
I'm unable to browse UPNP sources (source is another Kodi 17 install) with this skin nothing shows when I click on the source. It is a skin problem since switching to any other skin fixes the problem.
Kodi debug log http://pastebin.com/FbTS51qa
Tested on both a Linux computer and a Raspberry Pi running OSMC
Here is a screenshot
http://s000.tinyupload.com/?file_id=8536...9282356677
(2016-03-09, 05:25)shadow Wrote: [ -> ]I'm unable to browse UPNP sources (source is another Kodi 17 install) with this skin nothing shows when I click on the source. It is a skin problem since switching to any other skin fixes the problem.
Will be fixed with next sync, thx.
On the Apple TV 4 test builds if you open up a movie through the Apple TV top shelf the video details appear but there's no background behind it (to add contrast) since the details open on the main menu
This is an issue related to the Apple TV but it's also a skin issue at the same time...
On the MAC Kodi crashes when Extended Info is selected in a movie, debug log attached.
http://xbmclogs.com/pn7mpugrs
Thanks for the great program and fantastic new skin.
