2016-03-10, 11:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
2016-03-10, 13:11
(2016-03-09, 05:25)shadow Wrote: [ -> ]I'm unable to browse UPNP sources (source is another Kodi 17 install) with this skin nothing shows when I click on the source. It is a skin problem since switching to any other skin fixes the problem.
Kodi debug log http://pastebin.com/FbTS51qa
Tested on both a Linux computer and a Raspberry Pi running OSMC
Here is a screenshot
http://s000.tinyupload.com/?file_id=8536...9282356677
I have the same issue? Please let us now if this issue is already solved in current Krypton APK?
2016-03-10, 18:43
(2016-03-10, 13:11)itsmyworld18200 Wrote: [ -> ](2016-03-09, 05:25)shadow Wrote: [ -> ]I'm unable to browse UPNP sources (source is another Kodi 17 install) with this skin nothing shows when I click on the source. It is a skin problem since switching to any other skin fixes the problem.
Fixed once this here is merged:
https://github.com/xbmc/xbmc/pull/9313
2016-03-11, 03:27
I posted this elsewhere but I am thinking this is a skin related bug
http://goo.gl/5BG3Df
So far the Gui isn't displaying the root directory of UPNP file directories. tested on PLAYON browser server and Windows ten server.
It has occurred in Android and another poster confirmed it wasn't working in Ubuntu as well
Steps taken to replicate bug.
1. Add folders from TV or Movie category.
2. select UPNP folder
3. add specific UPNP server or Auto discovery..
4. server will add but directory will not display folders or files.
2016-03-11, 03:28
(2016-03-11, 03:27)tornicade Wrote: [ -> ]I posted this elsewhere but I am thinking this is a skin related bug
Please start to read, it´s just one post above.
2016-03-11, 03:36
(2016-03-11, 03:28)phil65 Wrote: [ -> ](2016-03-11, 03:27)tornicade Wrote: [ -> ]I posted this elsewhere but I am thinking this is a skin related bug
I did read it. I didn't know it was a skin issue and don't have the ability to merge. so I put it here.
and someone finally responded. thank you
do I mark my thread from yesterday resolved or does one of the mods do it?
2016-03-11, 09:42
"Choose information provider" in "Set Content"dialog inst translatable, at least not available in Transifex.
Also would you change "indexed" with "scanned" in "After the source has been added and indexed you will be able to browse your library."
If its the correct term ignore my request but to me its inconsistent because "scan" is used everywhere (i think) - "Scanning movies using", "Scan for new content", ''Scanning media information" and so on.
2016-03-11, 10:57
When MyMusicNav is showing songs the song artist(s) is not displayed. This is for all sort methods, and no matter what filtering (genre, artist, album etc.). Looking at compilation albums or playlists is particularly bad, but you also never see featured artists etc. when song artist is different from album artist.
2016-03-11, 20:16
Two minor bugs.
(Edit: Kodi version: 17.0-ALPHA1 Git:20160311-11912ea / Windows version)
Settings: You can't set new value for example Screensaver -> Dim -> Settings with keyboard only. There is no way to click OK and save. You can only escape from that slider with Esc or Backspace.
Another one affects tv/movie "info-screens". Using keyboard: after selecting actor and pressing up-arrow multiple times, actor info also opens multiple times and each one of them must be closed with esc/backspace separately. Same thing happens when "Extended info" button is selected and you press enter multiple times -> extended info opens multiple times.
There may be other places too where this kind of thing happens. Some sort of keystroke filtering ("allow only one up arrow/enter/whatever") shuld be perhaps in place where needed?
Other than that, no complaints. Skin looks great, it's easy to use and it certainly sends message that Kodi is still very much alive, active and kicking!
(Sorry for my language skills. I hope this still makes sense.)
2016-03-11, 20:52
Noticed a little issue that doesn't appear to have been mentioned yet, there doesn't seem to be any watched indicators for recordings in PVR.
EDIT: Another one, pressing up while playing a video to do a big skip doesn't show the seek bar.
Love the look BTW
Love the look BTW
2016-03-11, 22:27
seek is fixed the last couple of nightlys, upgrade.
2016-03-11, 22:32
2016-03-12, 21:39
Hi firstly love the new skin. i read through the post and did not see this mentioned.
The Forecast section under weather dose not populate with data.
using the yahoo weather addon on rp2 and ubuntu
the hourly forecast also dose not have data but confluence dose not have that subsection so i don't know if i would normally have that data.
I also notice when you go back to the main menu from settings more than one item are being focused on.
2016-03-14, 16:30
Love the skin!
During playback when I hover the pointer over the subtitles button, the context menu it appears; however, when I try to move the pointer up to click "Downlaod", the context menu disappears by the time I position my pointer over the text. If I move it really quickly I can manage to click Download, but without using a keyboard it's very difficult to access this context menu.
Also simply moving the pointer to "Enabled" causes the context menu to slide in/out 3 or 4 times, and if I'm not quick enough, I can't access this menu item either.
In this particular case, "Subtitle offset" and "Toggle language" are greyed out.
Love the new look and feel!
2016-03-15, 20:43
I have updated to latest daily and the mac still crashed when I launch extended info.
