2016-03-31, 00:23
Anyone else having addons with context menu's not showin up in the menu . This is an issue I was having with psuedolive settings export. I am pretty sure its an issue with the add on not being updated to the new skins .
(2016-03-30, 23:53)scott967 Wrote: [ -> ]On Windows 0330 build, seeing this in the log:
Code:11:48:13 T:3624 ERROR: Misplaced [
11:48:13 T:3624 ERROR: Error parsing boolean expression $EXP[infodialog_active]
but searching on infodialog_active I couldn't seeing anything amiss in the skin files.
Full log: http://xbmclogs.com/p1dkeixbn
scott s.
(2016-03-27, 08:00)MONSTA Wrote: [ -> ]Rpi2 still crashes on this skin when i try to scroll the files less than 2 Gb in the file manager. Larger no problem. I must change back to old skin for copy to another disc. Very inconveniently. On small files like samples about 100-300 Mb the system doesn't falls but slows.
Crashlog http://sprunge.us/cCUQ
Thank you
(2016-03-31, 02:39)Milhouse Wrote: [ -> ](2016-03-30, 23:53)scott967 Wrote: [ -> ]On Windows 0330 build, seeing this in the log:
scott s.
Not just Windows, in latest RPi test builds too, and in several places (Home screen, when entering Movies library etc.) - presumably from PR9488?
(2016-03-31, 02:11)mazey Wrote: [ -> ]latest skin sync, all OK but themes still don't work on android, guessing it might be a core problem?
(2016-03-30, 19:22)cojms1 Wrote: [ -> ]Am loving the skin so far.
Not sure if this is related to the variable mentioned by @Guilouz but, when using the Global search function the results are returned correctly but the screen no longer follows the theme that I have set (charcoal with default colours).
(2016-03-30, 03:51)Guilouz Wrote: [ -> ]Problem with your variable :
Code:<variable name="GlobalFanartVar">
<value condition="Skin.HasSetting(use_custom_bg) + !String.IsEmpty(Skin.String(custom_background))">$INFO[Skin.String(custom_background)]</value>
<value>special://skin/extras/backgrounds/$INFO[Skin.CurrentTheme].jpg</value>
</variable>
Must be :
<value>special://skin/extras/backgrounds/$INFO[Skin.CurrentColourTheme].jpg</value>
</variable>
(2016-03-31, 21:04)phil65 Wrote: [ -> ](2016-03-31, 02:11)mazey Wrote: [ -> ]latest skin sync, all OK but themes still don't work on android, guessing it might be a core problem?
correct, it´s related to packaging, not the skin itself.
(2016-03-31, 23:51)mazey Wrote: [ -> ]I think it will be fixed, but no promises. Since I completely separated color and theme selection today, you will be able to choose from all the colors at least for the time being (after next skin sync). The only thing missing then is the "curial" theme.(2016-03-31, 21:04)phil65 Wrote: [ -> ](2016-03-31, 02:11)mazey Wrote: [ -> ]latest skin sync, all OK but themes still don't work on android, guessing it might be a core problem?
do you think this will be fixed at some point? or would android miss out on theme changes due to some reason.
(2016-04-01, 01:01)mazey Wrote: [ -> ]i am able to select colours and change them atm, it only changes the text colour though. is that what you mean. id like to be able to change the background colour (im guessing that's what theme does).
(2016-04-01, 01:02)phil65 Wrote: [ -> ](2016-04-01, 01:01)mazey Wrote: [ -> ]i am able to select colours and change them atm, it only changes the text colour though. is that what you mean. id like to be able to change the background colour (im guessing that's what theme does).
As said, wait for the next sync (probably next week). Changing the color will work then regardless of whether themes are workin.
(2016-03-31, 21:07)phil65 Wrote: [ -> ](2016-03-30, 19:22)cojms1 Wrote: [ -> ]Am loving the skin so far.
That´s because the script contains XMLs which work as a fallback for all skins. Not sure if it is worth it to create estuary-only XMLs.
