Full Version: Bug reports
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
I am enjoying watching the development of this skin, every now and then I download a nightly build and have a look. Is there a development roadmap or sequence available where the delivery sequence of planned features is shown?
icons no longer highlight on android. might be due to lack of theme related functions. all icons on latest skin sync when selected the black turns to clear instead of highlighting with a color like it used to, lists work fine but all icons are affected.
EDIT: fixed with latest nightly strange i didnt see a commit that would fix it maybe the package failed to sync the required files when compiling last time, glad its fixed though Smile
In DialogVidoInfo.xml the label $LOCALIZE[20141] (movie set) should be $LOCALIZE[36910] to be correct in non-english installations.
(2016-04-17, 02:41)rodalpho Wrote: [ -> ]
(2016-04-16, 07:20)tailorgd Wrote: [ -> ]I'm having an issue using Primewire/1Channel since upgrading to v17 Krypton
Primewire and 1channel are piracy addons. Kodi does not support them and you can't discuss them here. I suggest you edit/delete your posts.
Ok, I wasnt aware of that. Sorry if this isnt the right place to discuss but as others are having the same problem with other add-ons couldn't there be a chance that this is something that could be looked into? Just trying to find an answer.
(2016-04-12, 07:25)startv Wrote: [ -> ]Language: chinese simple
Build: OpenELEC.tv Krypton build #0410: Generic
same thing with Hebrew, running Milhouse Libreelec
thanks!
When you add a source in videos the source is correctly added but the screen is not refreshed so you have no idea that it's actually added leading to trying to add again Sad
I have noticed a problem with using Yahoo Weather with Estuary. Any entry into location is rejected. From the log file it appears to be an Estuary issue. http://xbmclogs.com/ppzff1rwg
Please refer to lines around 879.
Select TV show episode info...
Select actor, e.g. Michael McKean, get a list of other stuff in your library where same actor appears...Image
...all good. If you then select one of those items and it's prefixed as a TV show or a Movie for example, then again, you get the expected info for that show or movie.
However, if it's listed as an episode (prefixed [Episode]), then you get the info with the correct fan-art and episode thumbnail, but with the cover art from the show you just linked from, i.e. for probably the wrong show:
What I'd expect to see:
Thx rickwookie, fixed on estuary repository.
(2016-04-20, 10:50)Tolriq Wrote: [ -> ]When you add a source in videos the source is correctly added but the screen is not refreshed so you have no idea that it's actually added leading to trying to add again Sad
That is a core issue then.
(2016-04-20, 19:49)bill_orange Wrote: [ -> ]I have noticed a problem with using Yahoo Weather with Estuary. Any entry into location is rejected. From the log file it appears to be an Estuary issue. http://xbmclogs.com/ppzff1rwg
The log error you pointed to is not related to that (should be fixed on latest master)
You specified $LOCALIZE[31133] in your DialogVideoInfo.xml but #31133 doesn't exist in your language file (on last git).
Estuary MOD V1.0.8 fixed this issue.
One more bug to be squashed: when you press the Trailer button on the movie details dialog, it will return to the movie list before playing the trailer, resulting in being presented with the list when the trailer has finished instead of still being presented with the movie details.
Small bug when watching TV shows.
In list vies, filtered on unwatched.
If you have a show where you have watched all previous seasons, you will jump right into the episode list for the new season when you select the show. (this is of course as it should be)
Now, what happens is that the season poster defaults to season 1 (or the season 0 poster if you have a season 0).
If you have two or more unwatched seasons, then it works like it should.
