Full Version: Undocumented AdvancedSettings
That are all the default settings and should be expanded and not be replaced.
Add one or more settings to the AdvancedSettings.xml if you want customize it.
List of strings to ignore directories that exactly named:
<Setting Section="*EmberAPP" Content="None" Name="NotValidDirIs" DefaultValue="">.actors|extrafanart|extrathumbs|video_ts|bdmv|audio_ts|recycler|subs|subtitles|.trashes</Setting>
List of strings to ignore directories that contains one of them in name:
<Setting Section="*EmberAPP" Content="None" Name="NotValidDirContains" DefaultValue="">-trailer|[trailer|temporary files|(noscan)|$recycle.bin|lost+found|system volume information|sample</Setting>
Regex to ignore files like trailers or samples (special regex / only available in 1.4.8.0 or higher):
<Setting Section="*EmberAPP" Content="None" Name="NotValidFileContains" DefaultValue="">[^\w\s]\s?trailer|[^\w\s]\s?sample</Setting>
Image quality while image resize (default is "100"):
<Setting Section="*EmberAPP" Content="Movie" Name="BannerQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="Movie" Name="ExtrafanartsQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="Movie" Name="ExtrathumbsQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="Movie" Name="FanartQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="Movie" Name="PosterQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVEpisode" Name="FanartQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVEpisode" Name="PosterQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVSeason" Name="BannerQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVSeason" Name="FanartQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVSeason" Name="PosterQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVShow" Name="BannerQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVShow" Name="ExtrafanartsQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVShow" Name="FanartQuality" DefaultValue="100">100</Setting>
<Setting Section="*EmberAPP" Content="TVShow" Name="PosterQuality" DefaultValue="100">100</Setting>
File Stacking parameters (remove p(?:ar)?t| if you've issues with titles that contains "Part"):
<Setting Section="*EmberAPP" Content="None" Name="FileStacking" DefaultValue="">(.*?)([ _.-]*(?:cd|dvd|p(?:ar)?t|dis[ck])[ _.-]*[0-9]+)(.*?)(\.[^.]+)$</Setting>
