Full Version: VDR + HDHomeRun Prime
Has anyone gotten VDR working with HDHomeRun Prime?
Ubuntu 14.0.4 (I'm not tied to this)
Kernel 4.2.0-27-generic
I have the hdhomerun dvb kernel module installed and am trying to get w_scan to make a channels.conf for use with VDR and failing... for days. I'd appreciate any help.
modinfo dvb-core
filename:       /lib/modules/4.2.0-27-generic/kernel/drivers/media/dvb-core/dvb-core.ko
license:        GPL
author:         Marcus Metzler, Ralph Metzler, Holger Waechtler
description:    DVB Core Driver
srcversion:     1A5C096BC8FA08738503433
depends:
intree:         Y
vermagic:       4.2.0-27-generic SMP mod_unload modversions
signer:         Build time autogenerated kernel key
sig_key:        73:6E:2F:9E:A1:B4:72:8A:15:AC:16:9B:18:69:26:7E:11:28:D6:E8
sig_hashalgo:   sha512
parm:           frontend_debug:Turn on/off frontend core debugging (default:off). (int)
parm:           dvb_shutdown_timeout:wait <shutdown_timeout> seconds after close() before suspending hardware (int)
parm:           dvb_force_auto_inversion:0: normal (default), 1: INVERSION_AUTO forced always (int)
parm:           dvb_override_tune_delay:0: normal (default), >0 => delay in milliseconds to wait for lock after a tune attempt (int)
parm:           dvb_powerdown_on_sleep:0: do not power down, 1: turn LNB voltage off on sleep (default) (int)
parm:           dvb_mfe_wait_time:Wait up to <mfe_wait_time> seconds on open() for multi-frontend to become available (default:5 seconds) (int)
parm:           cam_debug:enable verbose debug messages (int)
parm:           dvb_demux_tscheck:enable transport stream continuity and TEI check (int)
parm:           dvb_demux_speedcheck:enable transport stream speed check (int)
parm:           dvb_demux_feed_err_pkts:when set to 0, drop packets with the TEI bit set (1 by default) (int)
parm:           debug:Turn on/off debugging (default:off). (int)
parm:           dvbdev_debug:Turn on/off device debugging (default:off). (int)
w_scan -fa -cUS -fa
w_scan version 20130331 (compiled for DVB API 5.10)
using settings for UNITED STATES
ATSC
VSB US/CA, DVB-T TW
scan type TERRCABLE_ATSC, channellist 1
output format vdr-2.0
WARNING: could not guess your codepage. Falling back to 'UTF-8'
output charset 'UTF-8', use -C <charset> to override
Info: using DVB adapter auto detection.
main:3228: FATAL: ***** NO USEABLE TERRCABLE_ATSC CARD FOUND. *****
Please check wether dvb driver is loaded and
verify that no dvb application (i.e. vdr) is running.
jared@schuplex:~$ sudo su -
[sudo] password for jared:
root@schuplex:~# w_scan  -A2 -cUS -fa us-SD-Watertown
ATSC
QAM US/CA
scan type TERRCABLE_ATSC, channellist 2
        /dev/dvb/adapter0/frontend0 -> TERRCABLE_ATSC "HDHomeRun ATSC": good :-)
        /dev/dvb/adapter1/frontend0 -> TERRCABLE_ATSC "HDHomeRun ATSC": good :-)
        /dev/dvb/adapter2/frontend0 -> TERRCABLE_ATSC "HDHomeRun ATSC": good :-)
Using TERRCABLE_ATSC frontend (adapter /dev/dvb/adapter0/frontend0)
-_-_-_-_ Getting frontend capabilities-_-_-_-_
Using DVB API 5.a
frontend 'HDHomeRun ATSC' supports
INVERSION_AUTO
8VSB
16VSB
QAM_64
QAM_256
FREQ (54.00MHz ... 858.00MHz)
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
57000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
: 22 Invalid argument
initial_tune:2271: Setting frontend failed QAM256   f=57000 kHz
63000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=63000 kHz
69000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=69000 kHz
79000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=79000 kHz
85000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=85000 kHz
177000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=177000 kHz
183000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=183000 kHz
189000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=189000 kHz
195000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=195000 kHz
201000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=201000 kHz
207000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=207000 kHz
213000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=213000 kHz
123000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=123000 kHz
123012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=123012 kHz
129000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=129000 kHz
129012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=129012 kHz
135000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=135000 kHz
135012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=135012 kHz
141000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=141000 kHz
147000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=147000 kHz
153000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=153000 kHz
159000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=159000 kHz
165000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=165000 kHz
171000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=171000 kHz
219000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=219000 kHz
225000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=225000 kHz
231000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=231000 kHz
231012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=231012 kHz
237000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=237000 kHz
237012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=237012 kHz
243000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=243000 kHz
243012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=243012 kHz
249000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=249000 kHz
249012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=249012 kHz
255000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=255000 kHz
255012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=255012 kHz
261000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=261000 kHz
261012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=261012 kHz
267000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=267000 kHz
267012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=267012 kHz
273000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=273000 kHz
273012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=273012 kHz
279000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=279000 kHz
279012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=279012 kHz
285000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=285000 kHz
285012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=285012 kHz
291000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=291000 kHz
291012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=291012 kHz
297000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=297000 kHz
297012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=297012 kHz
303000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=303000 kHz
303012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=303012 kHz
309000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=309000 kHz
309012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=309012 kHz
315000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=315000 kHz
315012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=315012 kHz
321000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=321000 kHz
321012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=321012 kHz
327000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=327000 kHz
327012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=327012 kHz
333000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=333000 kHz
333012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=333012 kHz
339000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=339000 kHz
339012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=339012 kHz
345000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=345000 kHz
345012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=345012 kHz
351000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=351000 kHz
351012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=351012 kHz
357000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=357000 kHz
357012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=357012 kHz
363000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=363000 kHz
363012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=363012 kHz
369000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=369000 kHz
369012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=369012 kHz
375000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=375000 kHz
375012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=375012 kHz
381000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=381000 kHz
381012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=381012 kHz
387000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=387000 kHz
387012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=387012 kHz
393000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=393000 kHz
393012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=393012 kHz
399000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=399000 kHz
399012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=399012 kHz
405000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=405000 kHz
411000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=411000 kHz
417000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=417000 kHz
423000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=423000 kHz
429000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=429000 kHz
435000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=435000 kHz
441000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=441000 kHz
447000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=447000 kHz
453000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=453000 kHz
459000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=459000 kHz
465000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=465000 kHz
471000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=471000 kHz
477000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=477000 kHz
483000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=483000 kHz
489000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=489000 kHz
495000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=495000 kHz
501000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=501000 kHz
507000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=507000 kHz
513000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=513000 kHz
519000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=519000 kHz
525000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=525000 kHz
531000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=531000 kHz
537000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=537000 kHz
543000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=543000 kHz
549000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=549000 kHz
555000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=555000 kHz
561000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=561000 kHz
567000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=567000 kHz
573000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=573000 kHz
579000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=579000 kHz
585000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=585000 kHz
591000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=591000 kHz
597000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=597000 kHz
603000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=603000 kHz
609000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=609000 kHz
615000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=615000 kHz
621000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=621000 kHz
627000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=627000 kHz
633000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=633000 kHz
639000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=639000 kHz
645000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=645000 kHz
initial_tune:2271: Setting frontend failed QAM256   f=93000 kHz
initial_tune:2271: Setting frontend failed QAM256   f=99000 kHz
105000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=105000 kHz
111000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=111000 kHz
111012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=111012 kHz
117000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=117000 kHz
117012: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=117012 kHz
651000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=651000 kHz
657000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=657000 kHz
663000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=663000 kHz
669000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=669000 kHz
675000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=675000 kHz
681000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=681000 kHz
687000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=687000 kHz
693000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=693000 kHz
699000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=699000 kHz
705000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=705000 kHz
711000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=711000 kHz
717000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=717000 kHz
723000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=723000 kHz
729000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=729000 kHz
735000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=735000 kHz
741000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=741000 kHz
747000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=747000 kHz
753000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=753000 kHz
759000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=759000 kHz
765000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=765000 kHz
771000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=771000 kHz
777000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=777000 kHz
783000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=783000 kHz
789000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=789000 kHz
795000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=795000 kHz
801000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=801000 kHz
807000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=807000 kHz
813000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=813000 kHz
819000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=819000 kHz
825000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=825000 kHz
831000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=831000 kHz
837000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=837000 kHz
843000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=843000 kHz
849000: QAM256(time: 00:00) set_frontend:1849: ERROR: Setting frontend parameters failed (API v5.x)
initial_tune:2271: Setting frontend failed QAM256   f=849000 kHz
ERROR: Sorry - i couldn't get any working frequency/transponder
Nothing to scan!!
