2016-03-02, 05:37
2016-04-23, 07:25
I am making one atm you can manually download it from my GITHUB https://github.com/russellharrower/plugin.video.autv
2016-05-22, 00:00
Just put this in,works great.
2016-05-22, 02:23
Nope - most channels don't work and those that do suffer massive buffering. Not installable from main Kodi repository, only as a master zip
2016-05-28, 20:25
10 and one other channel don't work, others are good except for buffering.
I do have a problem with buffering on my Minix, all channels buffer bad but on my computer no buffering.Using Tunnelbear on both.
Wish I could figure out the problem. Using wireless on both computer and Minix.
2016-05-29, 20:25
Installed easy advanced settings using info here (removed garbage site promoting banned add-ons) Au channels buffering much less now, am still playing with the settings.
I've tried advanced settings in the past with no luck but this time it's actually working better.
*Mod edit
*Mod edit
2016-05-29, 22:25
Sorry I'm fairly new try to stick to the rules.Didn't look the site over, was just trying to find info on adding the advanced settings.
I'll be more careful.
2016-06-04, 00:28
I can't get 9 HD anymore, anybody else? 7,7mate,7 two,C31, and ABC24 still work good.
