Full Version: Kodi not allowing me to add-on from zip files.
Hi all,
I am trying to download repos from a zip file onto KODI so I can access some international channels.
The issue I am getting is that when I go to systems>add-ons>install from zip> select the drive/folder I am using (either SMB or USB)> then select the zip file, it does not let me select OK.
I have tried this with SMBup, with a USB, and I have even downloaded KODi on my PC - I am having the same problem with all of these options, it will just not let me select ok to download the zip file! I have tried other zip files including 2 repositories and one plug-in (playlist loader) and this happens with all of these files.
Does anyone have any idea what I am doing wrong?
Thanks in advance,
Kim
