(2016-03-01, 22:32)colbert Wrote: [ -> ] (2016-03-01, 13:20)Jayz2K Wrote: [ -> ] (2016-02-29, 20:06)pence Wrote: [ -> ]Digging the progress bars shogun. I'd be interested in the code once you are ready to share! I'm interested in learning more about this myself.
Also if anyone has a quick fix for adding episode air dates to the list view on widgets and/or addon viewing that would be awesome. I am using fixedlist type currently
Thank you guys!
Can you please check this :
http://forum.kodi.tv/showthread.php?tid=...pid2264655
(instructions at the bottom of the post)
Cheers
That is really good! Can you make for same list view that shows number of unwatched episodes instead of air date? I would like to set view for main TV shows list to show # unwatched, then when I go into the show view to display air date (so I could use this view already there).
replace the
$INFO[ListItem.Premiered, - $LOCALIZE[20416]
with:
$INFO[ListItem.Property(UnWatchedEpisodes)] Shows the number of unwatched episodes for the currently selected tvshow or season
*dont know what this 20416 string says !
(2016-03-02, 01:52)colbert Wrote: [ -> ] (2016-03-02, 00:28)reaven Wrote: [ -> ] (2016-03-01, 22:32)colbert Wrote: [ -> ]That is really good! Can you make for same list view that shows number of unwatched episodes instead of air date? I would like to set view for main TV shows list to show # unwatched, then when I go into the show view to display air date (so I could use this view already there).
replace the Code:
with:
I'm getting this: https://anonmgur.com/up/b5a06d8cebc7867c...5d4dcb.png
I was going to test it but something broke...
check lines around 113 and 220 of Designer_CustomList1.xml(the one you download, you have to change both control one for the focus item and the other for obviously the unfocused ones
<label>$VAR[B1SubTitle]$INFO[ListItem.Property(UnWatchedEpisodes)]</label>
or try
$VAR[B1SubTitle]$INFO[ListItem.Property(UnWatchedEpisodes), - $LOCALIZE[16101]
Ok I've got it showing the number of unwatched episodes, but the season doesn't go away. It shows "2 Seasons8 Unwatched" (I added "Unwatched" at the end of that code just for aesthetics). How to get rid of the Seasons attribute and replace it with unwatched number?
(2016-03-02, 04:53)colbert Wrote: [ -> ]Ok I've got it showing the number of unwatched episodes, but the season doesn't go away. It shows "2 Seasons8 Unwatched" (I added "Unwatched" at the end of that code just for aesthetics). How to get rid of the Seasons attribute and replace it with unwatched number?
try any of the two below (depends if you want space or dash )
or
$INFO[ListItem.Property(UnWatchedEpisodes),, $LOCALIZE[16101]]
it suppose to add the word ' unwatched '.
* $LOCALIZE[16101] - display Unwatched
and I didnt know you want to get rid of the season.., anyway I think is this bit $VAR[B1SubTitle], remove that to get rid of the season attribute
Remove $VAR[B1Subtitle]
$INFO[ListItem.Property(UnWatchedEpisodes),, $LOCALIZE[16101]] is the one.
PS : Take care about brackets at the end guys (dual closing one when using localize).
edit: Nevermind, I'm a moron! I forgot to change the start of each file "include name="CustomX"" to match the order I wanted, I had all 3 as Custom1
Okay fiiiinally I think I have it the way I want, showing # unwatched in main TV view, then in each episode view, air date + no thumbs:
If anyone is interested or as clueless as me, after trial and error I got it to show "Episode # - airdate" with:
$VAR[B1SubTitle] - $INFO[ListItem.Premiered,,, $LOCALIZE[20416]]
trying to work now in a song list viewtype that maybe would be usable as an episode viewtype too !
I'm trying to edit the line now to show a YouTube channel name for a YouTube add-on view, any ideas? Example:
So I would like to have that line be "Channel Name - Length"
(2016-03-04, 00:14)colbert Wrote: [ -> ]I'm trying to edit the line now to show a YouTube channel name for a YouTube add-on view, any ideas? Example:
Well, the name you're wanting to move is part of the item plot. Meaning you have to move the whole plot as subtitle which is not really clean. Have you search in the addon thread if an infolabel can show that ?
(2016-03-04, 13:13)Jayz2K Wrote: [ -> ] (2016-03-04, 00:14)colbert Wrote: [ -> ]I'm trying to edit the line now to show a YouTube channel name for a YouTube add-on view, any ideas? Example:
Oh I didn't realize that. The YouTube add-on seems to be currently in disarray, the author having stopped work on it at end of Dec from the thread. This is not important anyhow so no need to spend any time trying to figure it out.
