Full Version: Getting more done in GitHub with ZenHub
Tip; I have no affilicatrion with ZebHub but suggest that the Kodi team create a ZenHub account for XBMC Foundation (and Kodi) and use it for its extended/enhanced and collaboration project management in GitHub.
http://www.zenhub.io
ZenHub is the leading team collaboration and project management solution built for GitHub. And if you're building an open source software like Kodi then ZenHub is 100% free to use.
https://www.zenhub.io/open-source
To get set up with ZenHub, all you have to do is download the browser extension and log in with your GitHub account. Once you do, you’ll get access to ZenHub’s complete feature-set immediately.
What can ZenHub do?
ZenHub adds a series of enhancements directly inside the GitHub UI:
Real-time, customizable task boards for GitHub issues;
Burndown charts, estimates, and velocity tracking based on GitHub Milestones;
Personal to-do lists and task prioritization;
“+1” button for GitHub issues and comments;
Drag-and-drop file sharing;
Time-saving shortcuts like a quick repo switcher.
https://www.zenhub.io/?utm_source=ZHOnboarding
