I'm sure it's somewhere I just can't see. Just noticed there doesn't seem to be a playlists option under either music or video settings any longer. Where do I go through the menu system to make a smart playlist with nox?
Go to videos from main menu, last item in the list should be playlists, where you can edit/create smart playlists.
I had the videos menu item disabled of course
I am trying to create a smart playlist for audiobooks, and this will only allow me to make playlists for video based things. Why is there no option under music any longer? I guess I should have been more specific.
For music it's the same. May have to use the "library" submenu entry though instead of the main entry as that just opens where you left off previously.
