Hello,
I'm new in Kodi world.
I have a functional Kodi installation on Raspbery pi.
I would like to send and receive commands to kodi by node-red. I already have a kodi websocket defined in node-red, and I receive the messages emitted by kodi. But I'm unable to send a single "play/pause" command...
Does anybody had success with node-red + kodi ?
churchill
As I needed to command only a few features from kodi, I've installed the (great) mqtt plugin[1] to use with Node-red. So my problem is actually solved.
churchill
[1]
https://github.com/owagner/kodi2mqtt
(2016-03-03, 00:38)churchill Wrote: [ -> ]Hello,
churchill
We've developed appropriate koi plugin node-red-contrib-kodi:
https://www.npmjs.com/package/node-red-contrib-kodi
It has all functions you need and also stable tcp/ws connection with timeouts, ping, reconnect.
If you need some more info, contact me:
[email protected].
I hope it's ok to bump an old thread. I have installed this node-red package but when I enter my IP address it always show as inactive. I am running LibreELEC version 7.0.3, which is kodi 16.1. Should it still work on this version?
Thank you,
Mike
(2017-01-07, 16:20)mikecay Wrote: [ -> ]Hi,
Thank you,
Mike
It should work with such versions.
And node will be in status 'inactive' until you'll try to send some command to Kodi.
How can I make a node red dashboard entry of played file en time played from the mqtt messages.
I have tried a json converter that works voor total time / play time but on deploymend we are getting errors.
The played file is in error when I use json.
What is the correct string voor making een dashboard entry in node red?
