Full Version: Feature Requests
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
There are a few of us maintaining mods for Estuary adding features that have either been rejected or just personal taste.
Make the request and lets see how it goes Smile
Would be great to add possiblity to hide end time, duration and progress for some listitems. It would avoid spoilers for spot events for whom who can't watch live.
(2018-04-19, 01:26)mkorganashvili Wrote: [ -> ]Would be great to add possiblity to hide end time, duration and progress for some listitems. It would avoid spoilers for spot events for whom who can't watch live.
 You can do this with my mod v2 for Kodi 18.
Hello,
if you use Kodi with as many movies as i did, an "alphabethic scrollbar" would be very nice.
You know: if you are e.g. in Wall-View mode and press the right - button, until the scrollbar on the right side is highlighted,
as an additional step an alphabetic scrollbar for fast switching to e.g. the movies starting with an 'S' would be helpful.
At the moment, i switch to the scrollbar, press and hold the down button and release it, when the 'S' is shown.
If i'm lucky, i'm still within the 'S' - movies.
Just an idea. An example, how it could look, is in Media Elch.
I like the new skin anyway.
Greetings
Why not use shift-s or shift-st etc to get where you need?
Cause I don't use the keyboard. I use a programmed smart-mouse like a normal remote.
But you're right, that would be an option. Maybe i can program the smart-mouse somehow.
(2017-08-29, 13:59)ronvp Wrote: [ -> ]Anyway we can add Channel logos in the guide on each line and can we have a default widget for the live TV in the home menu? I like to be able to show a channel list or maybe the guide..
 tv icon can be added in Includes_PVR.xml look for <!--<control type="label" id="1">
you will eed to edit font.xml
for font0
<font>
   <name>font0</name>
   <filename>NotoSans-Regular.ttf</filename>
   <size>32</size>
   <style>bold</style>
  </font>
@Karellen- xml code removed. Too extensive.
@the_other_guy
Had to remove your code as it was just way to big for the forum. Please use links to Github for code dumps, or a pastebin type site if you don't have a git account.
https://nofile.io/f/0g8K6d2ry8W/epg.zip
files
Includes_PVR.xml
MyPVRGuide.xml
Since i have several channel groups from different tv sources i miss the option to sort the channels in epg timeline view by name and not only by channel number or channel group. I notice that sorting by channel name already work in tv channels view!
(2018-07-22, 20:00)tehax Wrote: [ -> ]Since i have several channel groups from different tv sources i miss the option to sort the channels in epg timeline view by name and not only by channel number or channel group. I notice that sorting by channel name already work in tv channels view!
 14231 (PR)
(2018-05-29, 23:26)moviefan65 Wrote: [ -> ]Hello,
you can do it with nodes
\Kodi\userdata\library\video\movies\
make a folder movies a-z
make index.xml
<?xml version='1.0' encoding='UTF-8'?>
<node order="5 A" type="folder" visible="Library.HasContent(Movies)">
 <label>Movies A - Z</label>
 <icon>AZ.png</icon>
 </node>
then you need to make the nodes for sorting the movies
a.xml
<node order="1" type="filter">
 <icon>a.png</icon>
<label>A</label>
 <name>a</name>
<content>movies</content>
<match>one</match>
<rule field="originaltitle" operator="startswith">
<value>a</value>
        <value>THE A</value>
    </rule>
</rule>
</node>
https://nofile.io/f/8sOefnMr0MF/a-z+movies.zip
Is there any possibility that an infolabel for "stars" could be added?  I would like to be able to get a short list of the lead actors/actresses from IMDB and add that info under the plot on list view so I can see who stars in the movie without switching to the info page.
I'd like to add to the Info  (Movie time, sound codec, HD) if there is a subtitle... it would be like:
1:45:00   2.0  AAC   720HD   EN/ES
It would be easy to know if already download a subtitle, and the languaje.
Is there option for autoscrolling titles with long names?
