2016-03-03, 20:07
Hi All,
I've been very happy with kodi/Isengard... It will play back just about anything I throw at it.... all except one type of mp4.
I wondered if anyone here could give me a clue as to why a mp4 encoded with get_iplayer plays back faultlessly but if you try to skip back or forth, one, two, or more seconds the image becomes blocky, freezes and sometimes locks up.
Firetv on 4.2.2 51.1.6.3 non-rooted. Using cat6 cable.
All material comes from a WD Nas drive. Only addons are iplayer, and youtube. (Had to get the "fixed" youtube as the one on offer that is no longer being updated crashes back to home screen). I think it might be something to do with api not being up to date on OS3.
I tested the same file on 15.2 Isengard on a laptop running win7 64bit and the file plays back and forth smoothly, even if i jump 5 or 10 mins.
So It must be something related to the firetv.
All files at 720p look the same as this: but SD material shows exactly the same problem.
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 28mn 59s
Bit rate mode : Variable
Bit rate : 2 300 Kbps
Maximum bit rate : 3 500 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.100
Stream size : 477 MiB (96%)
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 28mn 59s
Bit rate mode : Constant
Bit rate : 93.5 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Stream size : 19.4 MiB (4%)
Default : Yes
Alternate group : 1
The basic settings I use are : get_iplayer --get 831 --tvmode=best --subtitles (oh and I do pay my TV license if anyone was wondering)
any help/advice would be most welcome.
sadsack.
Format : AVC
Codec ID : avc1
Duration : 28mn 59s
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 28mn 59s
Default : Yes
Alternate group : 1
sadsack.
