Full Version: MLB.TV®
Still crashes with 14.40.33810.0
2024-07-22 18:33:09.207 T:20088    info <general>: AddOnLog: inputstream.adaptive: Manifest successfully parsed (Periods: 1, Streams in first period: 4, Type: live)
2024-07-22 18:33:09.207 T:20088    info <general>: Creating Demuxer
2024-07-22 18:33:09.208 T:20088    info <general>: Opening stream: 1001 source: 256
2024-07-22 18:33:10.201 T:20088 warning <general>: AddOnLog: inputstream.adaptive: adaptive::CHLSTree:TonguearseChildManifest: Cannot detect container type from media url, fallback to TS
https://www.mediafire.com/file/l26awqjud...0.zip/file
how come when I go to https://github.com/eracknaphobia/plugin....v/releases the latest is Release v2024.3.29 ?
(2024-07-23, 01:13)jimbobjones Wrote: [ -> ]how come when I go to https://github.com/eracknaphobia/plugin....v/releases the latest is Release v2024.3.29 ?
Here is will you'll find it  http://github.com/tonywagner/plugin.video.mlb
(2024-07-22, 13:33)tonywagner Wrote: [ -> ]Please direct any feedback to the new addon's forum thread: Release - MLB® (plugin.video.mlbserver)
It's not published as a release yet. But you can download the code of the master branch and install that ZIP file in Kodi just the same:
https://github.com/eracknaphobia/plugin....master.zip
(2024-07-22, 19:21)eracknaphobia Wrote: [ -> ]Version 2024.7.22+matrix.1 is on github please manually install and test.
It should fix the login and radio issues. I still have some code to cleanup but I wanted to get something out in the meantime.
eracknaphobia: I have stream padding, start at inning, and skipping working again. Can I open a pull request?
Edit to add: working ZIP is available at this fork:
https://github.com/tonywagner/plugin.vid...v/releases
(2024-07-23, 23:16)tonywagner Wrote: [ -> ]
(2024-07-22, 19:21)eracknaphobia Wrote: [ -> ]working ZIP is available at this fork:
Video, audio, skip to inning, and radio feeds tested and working Cool
(2024-07-24, 02:39)BulletSaloon Wrote: [ -> ]
But not "skip commercials".
"Skip commercials" is working!! Everything is great. Back to normal Blush
Great work!!
(2024-07-24, 03:29)hhqjdaasc Wrote: [ -> ]But not "skip commercials".
That should be fixed now too in the latest ZIP for that fork!
(2024-07-24, 04:22)tonywagner Wrote: [ -> ]
Confirmed - skip commercials is working in the latest zip.  I must have had the penultimate one.
Yes please, thanks for the fixes.
I've updated the releases on the github page and submitted the new version to the official kodi repo. Thanks @tonywagner for your continued support!
(2024-07-24, 17:52)eracknaphobia Wrote: [ -> ]I've updated the releases on the github page and submitted the new version to the official kodi repo. Thanks @tonywagner for your continued support!
Thanks to both of you!! Many thanks! Lots of thanks! Yay!!!
