Full Version: MLB.TV®
How long does it usually take for it to appear in the repo and auto update?
Once it gets reviewed it will be pulled in. Usually gets reviewed in a few days, but it can vary due to reviewers availability.
Has there been any movement on getting the updated addon into the official repo?
Highlights don't work. I get errors:
LOG
(2024-08-06, 04:27)3chainz Wrote: [ -> ]Has there been any movement on getting the updated addon into the official repo?
Not yet, you can get the latest version from the github repo https://github.com/eracknaphobia/plugin..../releases/
(2024-08-06, 19:06)Dixon Butz Wrote: [ -> ]Highlights don't work. I get errors:
LOG
Please use github to report future issues and tracking fixes. This one has been reported.
Highlights should now be fixed as of version 2024.8.6+matrix.1
forgot about github. Thanks.
What ever happened to "Condensed Games"?
(2024-08-07, 01:53)Dixon Butz Wrote: [ -> ]forgot about github. Thanks.
Should be listed under highlights.
Yep! I'm blind sometimes thanks!
The highlight start playing but then it locks up Kodi after 4 seconds.
With the NYY v LAA game today it was a double header, the 2nd game only had highlights as an option to select. I checked on MLB app and could access both games that way.
(2024-07-25, 10:33)jimbobjones Wrote: [ -> ]How long does it usually take for it to appear in the repo and auto update?
Usually, it takes a few days depending on the moderator review.
When I joined that game late, I could only get Spanish audio. Yes, I do know how to change audio stream.
(2024-08-08, 14:46)Dixon Butz Wrote: [ -> ]When I joined that game late, I could only get Spanish audio. Yes, I do know how to change audio stream.
I think that was broadcast error as it was english and then changed to spanish for an innings then changed back to english
