(2016-04-05, 23:26)sask3m Wrote: [ -> ] (2016-04-05, 18:45)Dixon Butz Wrote: [ -> ] (2016-04-05, 18:35)sask3m Wrote: [ -> ]Does this add-on have an audio option for what they refer to as "park audio" where all you get is the ball park sounds and no announcers? I remember seeing it on one of the many mlb.tv apps I've tried this spring but can't remember which it was.
Yes it does have it. Just change the audio stream until you find it. Should be stream unknown mono 3/4
OK, got it to work on # 3. I had to disable "enable pass through" or I had no audio at all. Thanks again.
Yeah that game does not have ballpark audio. Tried both home and away. So maybe not all games have that option. The 2 I tried earlier had it. One was today's Yankee game.
Is there a chance we get score Updates like your NHL Addon or the mlb don't support this ??
Is there a chance to get conseded Games or the highlight Feed or there arn't a feature this year?
(2016-04-05, 23:32)Dixon Butz Wrote: [ -> ] (2016-04-05, 23:26)sask3m Wrote: [ -> ] (2016-04-05, 18:45)Dixon Butz Wrote: [ -> ]Yes it does have it. Just change the audio stream until you find it. Should be stream unknown mono 3/4
Yeah I did get the ball park audio to work by disabling enable passtrough.
(2016-04-05, 23:08)sask3m Wrote: [ -> ] (2016-04-05, 22:30)newtonfb Wrote: [ -> ]Stupid question. Im watching on my Nvidia Shield, and its working awesome. How do i know if its 60FPS? I dont see anything indicating they are or arent.
On a PC you press o to see fps. Option likely isn't there for a streaming device. If it looks like a TV broadcast, nice and smooth then its 60 fps, if it has a slight stuttering look to it then its 30 fps. My android nexus player does 60 fps using this add-on so as long as the stream is 60 fps I'm sure the Nvidia shield will be as well.
Hmm. to be honestly i cant tell much difference, if any between the native android tv app and the kodi add on.
EDIT: Nevermind, I plugged my keyboard into my shield, hit the "O" and got the details. Looks like its going at 60fps. Awesome. Love that the add on is better than the native app! Thanks again
(2016-04-05, 23:39)sask3m Wrote: [ -> ] (2016-04-05, 23:32)Dixon Butz Wrote: [ -> ] (2016-04-05, 23:26)sask3m Wrote: [ -> ]OK, got it to work on # 3. I had to disable "enable pass through" or I had no audio at all. Thanks again.
Seems to be working on the home feed now even with passthrough enabled. But not on the away feed.
(2016-04-05, 05:00)sask3m Wrote: [ -> ]You need to get rid of mlbmc (is it even supported anymore?) and use this MLB.TV add-on, it's located on the first page of this thread.
Thanks, sask3m. Removed MLBMC and added the MLB.TV addon, and it's working.
I bounced here from another thread dealing with MLBMC and didn't check the first page
(2016-04-06, 00:04)newtonfb Wrote: [ -> ] (2016-04-05, 23:08)sask3m Wrote: [ -> ] (2016-04-05, 22:30)newtonfb Wrote: [ -> ]Stupid question. Im watching on my Nvidia Shield, and its working awesome. How do i know if its 60FPS? I dont see anything indicating they are or arent.
There is a good chance that the native app on your nvidia shield is 60 fps as I did read that some of the android tv's were doing 60. My android nexus player native app is only 30 fps yet my android phone gives me 60, go figure.
I wonder whats up with the Pirates not broadcasting their game tonight, no pirate feed on mlb.tv or on extra innings.
(2016-04-06, 01:33)sask3m Wrote: [ -> ]I wonder whats up with the Pirates not broadcasting their game tonight, no pirate feed on mlb.tv or on extra innings.
MLB support says: "Hello, the Pittsburgh pirates network station is not broadcasting this game tonight."
Some people are mad about this.
Is the nvidia shield working via the native app? Was thinking of picking one up if I would be able to fast forward through the game (the add on doesn't seem to give you a choice of starting at the beginning of the game and skipping through).
(2016-04-06, 01:30)sask3m Wrote: [ -> ] (2016-04-06, 00:04)newtonfb Wrote: [ -> ] (2016-04-05, 23:08)sask3m Wrote: [ -> ]On a PC you press o to see fps. Option likely isn't there for a streaming device. If it looks like a TV broadcast, nice and smooth then its 60 fps, if it has a slight stuttering look to it then its 30 fps. My android nexus player does 60 fps using this add-on so as long as the stream is 60 fps I'm sure the Nvidia shield will be as well.
Fabulous work, thank you for this addon.
I see there's an option to play highlights for old games. Any chance you can add another menu item to play the truncated game? It usually runs 15-20 mins and used to be free on mlb.mlb.com. Hope they are still there!
Here we go again! Can someone please explain why I go to a game watch it for a while then go to another game watch that for a while then try to go back to the first game I was watching and its GONE
Maybe it's a the bottom of the screen below what is visible and you need to scroll down?
340rag
When you are in the list if add-ons, in options sidebar, uncheck "Hide Watched"
