(2016-04-12, 17:31)eracknaphobia Wrote: [ -> ]Update 2016.4.12 Released
- Added Single Team Subscription setting
- Fixed Full Game not obeying the stream quality setting
Can someone please help me?
05:01:45 T:1790258512 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFFF69E20%5DB+2nd%5B%2FCOLOR%5D+D-backs+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D+at+Dodgers+%5BCOLOR%3DFF00B7EB%5D1%5B%2FCOLOR%5D&event_id=14-446968-2016-04-12&gid=2016%2F04%2F12%2Farimlb-lanmlb-1&teams_stream=arilan&stream_date=2016-04-12]
(2016-04-13, 12:40)fuggin Wrote: [ -> ] (2016-04-12, 15:08)eracknaphobia Wrote: [ -> ]12:40:54 T:1860526008 ERROR: CDVDPlayer::OpenInputStream - error opening [|User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=]
This is the problem: no stream url, no cookie. That is why I had you check your credentials, you are not getting logged in it appears. There is also a lot of other questionable addons / repos running and throwing errors in your log. I would suggest trying a fresh install of kodi on a PC if you are able. If the addon doesn't work on a fresh install then we can say this is a problem on my end.
@eracknaphobia
Using an mlb.com free account cannot play the free game of the day with your add-on.
Recap and Condensed play but Full games fail. See debug log.
Double checked credentials and logout numerous times.
Using a fresh install of your repo and version 2016.4.12 of the add-on.
Pointing a web browser to www.mlb.com/mediacenter plays the free game of the day flawlessly.
Seems the problem is on your end. Sure hope you can fix this. Cheers
P.S. it would be good if the add-on indicated the free game of the day.
Yep, never added this feature yet. Check to do list on first post.
(2016-04-13, 14:07)eracknaphobia Wrote: [ -> ]Yep, never added this feature yet. Check to do list on first post.
Fair enough. Archived free games worked during spring training. Must have been accidental or coincidence.
(2016-04-13, 14:02)Okieegirl85 Wrote: [ -> ] (2016-04-12, 17:31)eracknaphobia Wrote: [ -> ]Update 2016.4.12 Released
In a previous post eracnaphobia stated it does not appear that you are logging in correctly. You also claimed that you were using your U/P from mlb.com, I had mentioned to you earlier that you need to use your email/P in order to log in to mlb.tv, have you tried that yet?
(2016-04-13, 15:42)fuggin Wrote: [ -> ] (2016-04-13, 14:07)eracknaphobia Wrote: [ -> ]Yep, never added this feature yet. Check to do list on first post.
It appears this has to do with the playback scenario. The free games aren't allowed the 60 fps feed, if you enable "Single Team subscription" in the addon settings you will be able to watch the free games. I am currently working on highlighting them in the menu and rewording that setting to cover free games too.
(2016-04-13, 17:19)sask3m Wrote: [ -> ] (2016-04-13, 14:02)Okieegirl85 Wrote: [ -> ] (2016-04-12, 17:31)eracknaphobia Wrote: [ -> ]Update 2016.4.12 Released
Yes, I have entered my email and password numerous times.
(2016-04-13, 23:06)Okieegirl85 Wrote: [ -> ]Yes, I have entered my email and password numerous times.
Try pressing the "Logout" button. Then trying again. I was having this problem, as soon as i pressed "Logout" it worked fine.
Ever since the update MLB.TV is not functional. I tried logging out. Not sure what is going on...
It will not allow to view "Today's Games" I have tried toggling the single game subscription on and off.
Is there anywhere we can get the old version?
Works flawlessly on my Asus Chromebox! Even better than when streaming it straight from the MLB.com website via a web browser.
Thanks for working on this.
It is not working on the Fire TV anymore
I'm using it on a fire tv right now. If Today's games won't load you have deeper issues than your login. Sounds like network or dns/vpn issues.
Updated to newest release and buffering issues with Jays games seem to be gone. Thanks.
(2016-04-14, 03:07)eracknaphobia Wrote: [ -> ]I'm using it on a fire tv right now. If Today's games won't load you have deeper issues than your login. Sounds like network or dns/vpn issues.
Is there any location that the old version is available so I may troubleshoot? It has been totally working up until now. Where there any new URL's added in the new version?
(2016-04-14, 03:32)rocketr Wrote: [ -> ] (2016-04-14, 03:07)eracknaphobia Wrote: [ -> ]I'm using it on a fire tv right now. If Today's games won't load you have deeper issues than your login. Sounds like network or dns/vpn issues.
Sure, knock yourself out:
https://github.com/eracknaphobia/repo.er...ideo.mlbtv
There hasn't been any changes that would make today's games not load. That has not changed since the beginning and it requires no authentication to retrieve the game list.
