After update my live games stopped working but figured it out.
Somehow in the settings the stream quality preference was changed to a low sd setting
Changed it back to hd (5000) and works again.
Hope this helps.
edit: I can confirm this happened on multiple devices.
(2016-04-14, 03:07)eracknaphobia Wrote: [ -> ]I'm using it on a fire tv right now. If Today's games won't load you have deeper issues than your login. Sounds like network or dns/vpn issues.
I got it working! It must of been my credentials Lol. I thank you for your awesome app, the picture is even clearer than my Dish HD. Thank you very much
(2016-04-14, 01:24)Kewjoe Wrote: [ -> ] (2016-04-13, 23:06)Okieegirl85 Wrote: [ -> ]Yes, I have entered my email and password numerous times.
Try pressing the "Logout" button. Then trying again. I was having this problem, as soon as i pressed "Logout" it worked fine.
I tried what you said and it works! I appreciate your help. GOD Bless
I downloaded the repository from the 1st post and the MLB.TV addon is not in the repository? Has it been removed? If so can someone provide a link to the zip?
(2016-04-14, 04:08)pett Wrote: [ -> ]After update my live games stopped working but figured it out.
Hope this helps.
I noticed this too... if the addon updates and your Live games are not working, go into the settings and check the stream preferences. Mine defaulted to the lowest possible setting, which probably is not an available rate for those games. Once I bumped it up, everything worked like a charm.
(2016-04-14, 14:24)fjhthree Wrote: [ -> ]I downloaded the repository from the 1st post and the MLB.TV addon is not in the repository? Has it been removed? If so can someone provide a link to the zip?
What version of Kodi? By default, Kodi will hide addons that are not compatible. If you are on a current version of Kodi, reboot the unit and see if that helps.
(2016-04-14, 14:49)sdsnyr94 Wrote: [ -> ] (2016-04-14, 14:24)fjhthree Wrote: [ -> ]I downloaded the repository from the 1st post and the MLB.TV addon is not in the repository? Has it been removed? If so can someone provide a link to the zip?
Yes, I am using the current version. I will reboot when I get home later today and see what happens. Is there a plan B to keep Kodi from hiding incompatible addons?
(2016-04-14, 15:17)fjhthree Wrote: [ -> ] (2016-04-14, 14:49)sdsnyr94 Wrote: [ -> ] (2016-04-14, 14:24)fjhthree Wrote: [ -> ]I downloaded the repository from the 1st post and the MLB.TV addon is not in the repository? Has it been removed? If so can someone provide a link to the zip?
Here is a link to all the mlb plug ins. Click on Raw to download the one you want.
https://github.com/eracknaphobia/repo.er...ideo.mlbtv
Current as in 16.x, or current as in Alpha 17? I have not tested on Krypton.
(2016-04-14, 16:57)sask3m Wrote: [ -> ] (2016-04-14, 15:17)fjhthree Wrote: [ -> ] (2016-04-14, 14:49)sdsnyr94 Wrote: [ -> ]What version of Kodi? By default, Kodi will hide addons that are not compatible. If you are on a current version of Kodi, reboot the unit and see if that helps.
Thanks that worked. I am good to go.
(2016-04-14, 17:13)sdsnyr94 Wrote: [ -> ] (2016-04-14, 15:17)fjhthree Wrote: [ -> ] (2016-04-14, 14:49)sdsnyr94 Wrote: [ -> ]What version of Kodi? By default, Kodi will hide addons that are not compatible. If you are on a current version of Kodi, reboot the unit and see if that helps.
I got it working using the link sask3m provided; however, I am using 16.xm, not Alpha 7.
Any idea why I can't seem to watch individual game recaps, or condensed games? Full games, both live and archived work fine. I'm not on the single team package. This happens for every team. The condensed games/recaps work fine on AppleTV & the PS3. Quality is set to "Best Available". Log error below.
Love the plugin by the way! Many thanks for making this.
Log entry:
22:10:58 T:1568 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('url',)
File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.mlbtv\main.py", line 916, in <module>
streamSelect(event_id, gid, teams_stream, stream_date)
File "C:\Users\Matt\AppData\Roaming\Kodi\addons\plugin.video.mlbtv\main.py", line 308, in streamSelect
stream_url = recap['url']
KeyError: ('url',)
22:10:58 T:1780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BB%5D%5BCOLOR%3DFFF69E20%5DGame+Over%5B%2FCOLOR%5D+%5BCOLOR%3DFFE4002B%5DYankees%5B%2FCOLOR%5D+%5BCOLOR%3DFF00B7EB%5D2%5B%2FCOLOR%5D+at+Blue+Jays+%5BCOLOR%3DFF00B7EB%5D7%5B%2FCOLOR%5D%5B%2FB%5D&event_id=14-446992-2016-04-13&gid=2016%2F04%2F13%2Fnyamlb-tormlb-1&teams_stream=nyator&stream_date=2016-04-13]
Did this stop working for anyone else today? I'm getting:
15:07:29 T:5080 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
15:07:29 T:5080 NOTICE: CDVDPlayer::OnExit()
15:07:29 T:5368 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFFF69E20%5DB+7th%5B%2FCOLOR%5D+Braves+at+Nationals&event_id=14-446997-2016-04-14&gid=2016%2F04%2F14%2Fatlmlb-wasmlb-1&teams_stream=atlwas&stream_date=2016-04-14]
15:07:29 T:5368 NOTICE: CDVDPlayer::CloseFile()
15:07:29 T:5368 NOTICE: DVDPlayer: waiting for threads to exit
15:07:29 T:5368 NOTICE: DVDPlayer: finished waiting
I couldn't find an answer to this so I figured I'd ask.
I can open the games through Kodi perfectly on Windows 10. But when I use my Nvidia Shield Android TV I can only watch recaps. The live games won't play.
I've tried uninstalling and reinstalling and making sure I entered my credentials correctly. If it is not a known issue I can provide a log. Thanks!
UPDATE:
Nevermind I figured it out. I wasn't authenticating properly on the Shield. Just had to press logout lol.
(2016-04-14, 14:47)sdsnyr94 Wrote: [ -> ] (2016-04-14, 04:08)pett Wrote: [ -> ]After update my live games stopped working but figured it out.
Hope this helps.
This solved my problem after an update, thanks for the tip.
