Full Version: MLB.TV®
Pretty soon were gonna need a FAQ sheet for the tips. Smile
Hello there. I just installed the MLB.TV video add-on but I am not getting any video (sound is ok).
Running Kodi 16.0 Jarvis on a SkyStreamX 4 Streaming Media Player running Android (ARM architecture).
Can anyone help me out with this? What could be the problem here? Thanks in advance.
Follows is the Kodi.log file
16:51:49 T:1747194384 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:51:49 T:1747194384 NOTICE: -----------------------------------------------------------------------
16:51:49 T:1747194384 NOTICE: Starting Kodi (16.0 Git:2016-02-20-a5f3a99). Platform: Android ARM 32-bit
16:51:49 T:1747194384 NOTICE: Using Release Kodi x32 build
16:51:49 T:1747194384 NOTICE: Kodi compiled Feb 20 2016 by GCC 4.8.0 for Android ARM 32-bit API level 17 (API level 17)
16:51:49 T:1747194384 NOTICE: Running on MBX SkystreamX X4 with Android 4.4.2 API level 19, kernel: Linux ARM 32-bit version 3.10.33
16:51:49 T:1747194384 NOTICE: FFmpeg version: 2.8.6-kodi-2.8.6-Jarvis-16.0
16:51:49 T:1747194384 NOTICE: Host CPU: ARMv7 Processor rev 1 (v7l), 4 cores available
16:51:49 T:1747194384 NOTICE: Product: M8N, Device: M8N, Board: M8N - Manufacturer: MBX, Brand: MBX, Model: SkystreamX X4, Hardware: amlogic
16:51:49 T:1747194384 NOTICE: External storage path = /storage/emulated/0; status = ok
16:51:49 T:1747194384 NOTICE: ARM Features: Neon enabled
16:51:49 T:1747194384 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
16:51:49 T:1747194384 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
16:51:49 T:1747194384 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
16:51:49 T:1747194384 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
16:51:49 T:1747194384 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
16:51:49 T:1747194384 NOTICE: The executable running is:
16:51:49 T:1747194384 NOTICE: Local hostname: localhost
16:51:49 T:1747194384 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
16:51:49 T:1747194384 NOTICE: load settings...
16:51:49 T:1747194384 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
16:51:49 T:1747194384 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
16:51:49 T:1747194384 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
16:51:49 T:1747194384 DEBUG: AESinkAUDIOTRACK - 44100 supported
16:51:49 T:1747194384 DEBUG: AESinkAUDIOTRACK - 48000 supported
16:51:49 T:1747194384 NOTICE: Found 1 Lists of Devices
16:51:49 T:1747194384 NOTICE: Enumerated AUDIOTRACK devices:
16:51:49 T:1747194384 NOTICE: Device 1
16:51:49 T:1747194384 NOTICE: m_deviceName : AudioTrack
16:51:49 T:1747194384 NOTICE: m_displayName : android
16:51:49 T:1747194384 NOTICE: m_displayNameExtra: audiotrack
16:51:49 T:1747194384 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
16:51:49 T:1747194384 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR
16:51:49 T:1747194384 NOTICE: m_sampleRates : 48000,44100,48000
16:51:49 T:1747194384 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
16:51:49 T:1747194384 DEBUG: CSkinSettings: no <skinsettings> tag found
16:51:49 T:1747194384 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:51:49 T:1747194384 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:51:49 T:1747194384 NOTICE: Default DVD Player: dvdplayer
16:51:49 T:1747194384 NOTICE: Default Video Player: dvdplayer
16:51:49 T:1747194384 NOTICE: Default Audio Player: paplayer
16:51:49 T:1747194384 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:51:49 T:1747194384 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
16:51:49 T:1747194384 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:51:49 T:1747194384 NOTICE: Loaded playercorefactory configuration
16:51:49 T:1747194384 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:51:49 T:1747194384 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:51:49 T:1747194384 NOTICE: Running database version Addons20
16:51:49 T:1747194384 NOTICE: ADDONS: Using repository repository.xbmc.org
16:51:49 T:1747194384 NOTICE: ADDONS: Using repository repository.eracknaphobia
16:51:49 T:1747194384 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: amlandroid
16:51:49 T:1747194384 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
16:51:49 T:1747194384 NOTICE: Previous line repeats 1 times.
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 720 x 480i @ 60.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 720 x 480 @ 60.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 720 x 576i @ 50.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 720 x 576 @ 50.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1280 x 720 @ 60.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1280 x 720 @ 50.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 30.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 25.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 24.000000 Hz
16:51:49 T:1747194384 NOTICE: Found resolution 1920 x 1080 for display 0 with 4096 x 2160 @ 24.000000 Hz
16:51:49 T:1747194384 NOTICE: Found ([email protected]) at 20, setting to RES_DESKTOP at 16
16:51:49 T:1747194384 NOTICE: Checking resolution 16
16:51:49 T:1747194384 NOTICE: GL_VENDOR = ARM
16:51:49 T:1747194384 NOTICE: GL_RENDERER = Mali-450 MP
16:51:49 T:1747194384 NOTICE: GL_VERSION = OpenGL ES 2.0
16:51:49 T:1747194384 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
16:51:49 T:1747194384 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil
16:51:50 T:1747194384 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
16:51:50 T:1747194384 ERROR: Unable to load libcec.so, reason: (null)
16:51:50 T:1747194384 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
16:51:50 T:1747194384 NOTICE: Running database version Addons20
16:51:50 T:1747194384 NOTICE: Running database version ViewModes6
16:51:50 T:1747194384 NOTICE: Running database version Textures13
16:51:50 T:1747194384 NOTICE: Running database version MyMusic56
16:51:50 T:1747194384 NOTICE: Running database version MyVideos99
16:51:50 T:1747194384 NOTICE: Running database version TV29
16:51:50 T:1747194384 NOTICE: Running database version Epg11
16:51:50 T:1747194384 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
16:51:50 T:1747194384 NOTICE: ActiveAE DSP - starting
16:51:50 T:1747194384 NOTICE: initialize done
16:51:50 T:1747194384 NOTICE: Running the application...
16:51:51 T:1747194384 NOTICE: starting zeroconf publishing
16:51:51 T:1747194384 NOTICE: starting upnp client
16:51:51 T:1747194384 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
16:51:51 T:1747194384 NOTICE: GL_VENDOR = ARM
16:51:51 T:1747194384 NOTICE: GL_RENDERER = Mali-450 MP
16:51:51 T:1747194384 NOTICE: GL_VERSION = OpenGL ES 2.0
16:51:51 T:1747194384 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
16:51:51 T:1747194384 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil
16:51:51 T:1895486968 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:51:51 T:1895486968 NOTICE: UDP: Listening on port 9777
16:52:07 T:1772387896 WARNING: Attempt to use invalid handle 3
16:52:07 T:1747194384 NOTICE: DVDPlayer: Opening: http://mlblive-akc.mlb.com/ls04/mlbam/20...pplication libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b88e2ad0f64782793646fbcceaf922b0e20cc0cee20b08d9f3f99da3188ebad617fc93565dd40c32025ad95406378b53b34b6d29ecef64dd672ddb6f430beaa983ff573aa683da4d3212a3e52daf61e2bfbc4eea1f11fb6e1ffc4073f8f88f5c4fdee63bfc80005236d65838c663737de47320cc534f3f84be7396cda4ce9234b8f6c144c0fc77f7f139b4fa3e5b9326a5415b885c3c0a12408a9498d5eb92db00
16:52:07 T:1747194384 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
16:52:07 T:1933350104 NOTICE: Creating InputStream
16:52:07 T:1933350104 NOTICE: Creating Demuxer
16:52:10 T:1933350104 NOTICE: Opening stream: 0 source: 256
16:52:10 T:1933350104 NOTICE: Creating video codec with codec id: 28
16:52:10 T:1933350104 NOTICE: Creating video thread
16:52:10 T:1933350104 NOTICE: Opening stream: 1 source: 256
16:52:10 T:1933350104 NOTICE: Finding audio codec for: 86018
16:52:10 T:1913753376 NOTICE: running thread: video_thread
16:52:10 T:1933350104 NOTICE: Creating audio thread
16:52:10 T:1914867552 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
16:52:10 T:1914867552 NOTICE: Creating audio stream (codec id: 86018, channels: 1, sample rate: 48000, no pass-through)
16:52:10 T:1914867552 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 4 packets of duration 21
16:52:13 T:1914867552 NOTICE: Previous line repeats 2 times.
16:52:13 T:1914867552 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 3 packets of duration 21
16:52:13 T:1914867552 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
16:52:40 T:1914867552 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
16:52:44 T:1914867552 WARNING: Previous line repeats 1 times.
16:52:44 T:1914867552 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
16:52:44 T:1914867552 NOTICE: Previous line repeats 2 times.
16:52:44 T:1914867552 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 1 packets of duration 21
16:52:55 T:1747194384 NOTICE: CDVDPlayer::CloseFile()
16:52:55 T:1747194384 NOTICE: DVDPlayer: waiting for threads to exit
16:52:55 T:1933350104 NOTICE: CDVDPlayer::OnExit()
16:52:55 T:1933350104 NOTICE: Closing stream player 1
16:52:55 T:1933350104 NOTICE: Waiting for audio thread to exit
16:52:55 T:1914867552 NOTICE: thread end: CDVDPlayerAudio::OnExit()
16:52:55 T:1933350104 NOTICE: Closing audio device
16:52:55 T:1933350104 NOTICE: Deleting audio codec
16:52:55 T:1933350104 NOTICE: Closing stream player 2
16:52:55 T:1933350104 NOTICE: waiting for video thread to exit
16:52:55 T:1913753376 NOTICE: thread end: video_thread
16:52:55 T:1933350104 NOTICE: deleting video codec
16:52:55 T:1747194384 NOTICE: DVDPlayer: finished waiting
16:52:59 T:1747194384 NOTICE: Storing total System Uptime
16:52:59 T:1747194384 NOTICE: Saving settings
16:52:59 T:1747194384 NOTICE: stop all
16:52:59 T:1747194384 NOTICE: stop player
16:52:59 T:1747194384 NOTICE: ES: Stopping event server
16:52:59 T:1747194384 NOTICE: stopping upnp
16:52:59 T:1747194384 NOTICE: stopping zeroconf publishing
16:53:00 T:1895486968 NOTICE: ES: UDP Event server stopped
16:53:00 T:1747194384 NOTICE: stop sap announcement listener
16:53:00 T:1747194384 NOTICE: clean cached files!
16:53:00 T:1747194384 NOTICE: unload skin
16:53:00 T:1747194384 NOTICE: stopped
16:53:00 T:1747194384 NOTICE: destroy
16:53:00 T:1747194384 NOTICE: closing down remote control service
16:53:00 T:1747194384 NOTICE: unload sections
16:53:00 T:1747194384 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:53:00 T:1747194384 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
16:53:00 T:1747194384 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
16:53:00 T:1747194384 NOTICE: application stopped...
(2016-04-15, 22:25)marcj Wrote: [ -> ]Hello there. I just installed the MLB.TV video add-on but I am not getting any video (sound is ok).
Have you tried changing the stream quality in the add-on settings? My tablet displays similar behavior from time to time, and lowering the bitrate sometimes helps.
Has any got the MLB addon to work on Mac OSX?
(2016-04-16, 00:27)sportshd Wrote: [ -> ]Has any got the MLB addon to work on Mac OSX?
Yes. Are you having trouble? The process has been pretty much identical for me, across Mac, Windows, Android, and Fire TV.
(2016-04-16, 00:21)MetalChris Wrote: [ -> ]
Thanks for your reply. But I have tried lowering the stream quality but to no avail I still do not get any video. What I have noticed is that playing either a condensed/recap game the video works. Buy playing either a live game or a full game that has finished already does not display the video.
Here is a snapshot of the log file that was produced. Hope someone can help me out. Thank you.
Log file without video (Full game):
06:05:12 T:1789873488 NOTICE: GL_VENDOR = ARM
06:05:12 T:1789873488 NOTICE: GL_RENDERER = Mali-450 MP
06:05:12 T:1789873488 NOTICE: GL_VERSION = OpenGL ES 2.0
06:05:12 T:1789873488 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
06:05:12 T:1789873488 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil
06:05:36 T:1789873488 NOTICE: DVDPlayer: Opening: http://mlblive-akc.mlb.com/ls04/mlbam/20...pplication libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b83e0f771eaaf3e15d993832acb48e3861bad3353dd6a42e13a17b51ea1c3223ede83cfd51996d74e3934f513fd8dfb7d60c75204e3fbe5fc2e66df7d01a9451027166b26303658f958ff182ec28a9a40df1d16a4f14b6e6d24bc01bce5954b7762dfeaf85cc07bff9e2cbe316f4c9da6f2d26a74ade813e401fc2f1a18738a4fa659bac0c6479005b9c1baf534fcf027a875e9baec56671fa10e1bac8eec97ffa232f08d0cfafb0e54642952e3f641a4c
06:05:36 T:1789873488 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
06:05:36 T:1864541864 NOTICE: Creating InputStream
06:05:37 T:1864541864 NOTICE: Creating Demuxer
06:05:39 T:1864541864 NOTICE: Opening stream: 0 source: 256
06:05:39 T:1864541864 NOTICE: Creating video codec with codec id: 28
06:05:39 T:1864541864 NOTICE: Creating video thread
06:05:39 T:1864541864 NOTICE: Opening stream: 1 source: 256
06:05:39 T:1907933416 NOTICE: running thread: video_thread
06:05:39 T:1864541864 NOTICE: Finding audio codec for: 86018
06:05:39 T:1864541864 NOTICE: Creating audio thread
06:05:39 T:1858092416 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
06:05:39 T:1858092416 NOTICE: Creating audio stream (codec id: 86018, channels: 1, sample rate: 48000, no pass-through)
06:05:39 T:1858092416 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 4 packets of duration 21
06:05:40 T:1858092416 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:05:44 T:1791071392 ERROR: Previous line repeats 2 times.
06:05:44 T:1791071392 ERROR: ActiveAE::bool ActiveAE::CActiveAE::InitSink() - failed to init
06:05:44 T:1791071392 WARNING: CActiveAE::void ActiveAE::CActiveAE::StateMachine(int, Actor:Tonguerotocol*, Actor::Message*) - signal: 10 from port: OutputControlPort not handled for state: 1
06:05:44 T:1791071392 WARNING: CActiveAE::void ActiveAE::CActiveAE::StateMachine(int, Actor:Tonguerotocol*, Actor::Message*) - signal: 11 from port: OutputControlPort not handled for state: 1
06:05:44 T:1858092416 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:05:45 T:1907933416 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
06:05:46 T:1858092416 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:05:46 T:1858092416 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
06:05:46 T:1907933416 NOTICE: Previous line repeats 249 time
06:05:46 T:1907933416 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
06:05:47 T:1858092416 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:05:47 T:1858092416 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
06:05:49 T:1858092416 NOTICE: Previous line repeats 75 times.
06:05:49 T:1858092416 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:05:49 T:1858092416 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
06:05:51 T:1858092416 NOTICE: Previous line repeats 74 times.
06:05:51 T:1858092416 ERROR: CDVDAudio::AddPacketsRenderer - timeout adding data to renderer
06:05:51 T:1858092416 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
Log file of Recap/Condensed game:
06:27:33 T:1855873904 NOTICE: GL_VENDOR = ARM
06:27:33 T:1855873904 NOTICE: GL_RENDERER = Mali-450 MP
06:27:33 T:1855873904 NOTICE: GL_VERSION = OpenGL ES 2.0
06:27:33 T:1855873904 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
06:27:33 T:1855873904 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil
06:27:33 T:1855873904 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
06:27:36 T:1855873904 ERROR: Unable to load libcec.so, reason: (null)
06:27:36 T:1855873904 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
06:27:36 T:1855873904 NOTICE: Running database version Addons20
06:27:36 T:1855873904 NOTICE: Running database version ViewModes6
06:27:36 T:1855873904 NOTICE: Running database version Textures13
06:27:36 T:1855873904 NOTICE: Running database version MyMusic56
06:27:36 T:1855873904 NOTICE: Running database version MyVideos99
06:27:36 T:1855873904 NOTICE: Running database version TV29
06:27:36 T:1855873904 NOTICE: Running database version Epg11
06:27:37 T:1855873904 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
06:27:37 T:1855873904 NOTICE: ActiveAE DSP - starting
06:27:37 T:1855873904 NOTICE: initialize done
06:27:37 T:1855873904 NOTICE: Running the application...
06:27:37 T:1855873904 NOTICE: starting zeroconf publishing
06:27:37 T:1855873904 NOTICE: starting upnp client
06:27:37 T:1880869944 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
06:27:37 T:1855873904 NOTICE: Current resolution: 1920x1080 @ 60.00 - Full Screen
06:27:37 T:1880869944 NOTICE: UDP: Listening on port 9777
06:27:37 T:1855873904 NOTICE: GL_VENDOR = ARM
06:27:37 T:1855873904 NOTICE: GL_RENDERER = Mali-450 MP
06:27:37 T:1855873904 NOTICE: GL_VERSION = OpenGL ES 2.0
06:27:37 T:1855873904 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
06:27:37 T:1855873904 NOTICE: GL_EXTENSIONS = GL_EXT_debug_marker GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil
06:28:01 T:1855873904 NOTICE: DVDPlayer: Opening: http://mediadownloads.mlb.com/mlbam/hls/...eMedia/1.0 ( iPad; compatible; 3ivx HLS Engine/2.0.0.382; Win8; x64; 264P AACP AC3P AESD CLCP HTPC HTPI HTSI MP3P MTKA)
06:28:01 T:1855873904 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
06:28:01 T:1933283656 NOTICE: Creating InputStream
06:28:01 T:1933283656 NOTICE: Creating Demuxer
06:28:02 T:1933283656 NOTICE: Opening stream: 0 source: 256
06:28:02 T:1933283656 NOTICE: Creating video codec with codec id: 28
06:28:02 T:1933283656 NOTICE: Creating video thread
06:28:02 T:1933283656 NOTICE: Opening stream: 1 source: 256
06:28:02 T:1933283656 NOTICE: Finding audio codec for: 86018
06:28:02 T:1943091344 NOTICE: running thread: video_thread
06:28:02 T:1933283656 NOTICE: Creating audio thread
06:28:02 T:1932198688 NOTICE: running thread: CDVDPlayerAudio:Tonguerocess()
06:28:02 T:1932198688 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
06:28:02 T:1932198688 NOTICE: CDVDPlayerAudio::OutputPacket duplicate 4 packets of duration 21
06:28:02 T:1943091344 NOTICE: fps: 29.970030, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
06:28:02 T:1943091344 NOTICE: Display resolution DESKTOP : 1280x720 @ 60.00 - Full Screen (16)
06:28:02 T:1855873904 NOTICE: Using GL_TEXTURE_2D
06:28:02 T:1855873904 NOTICE: GL: Using BYPASS render method
06:28:02 T:1855873904 NOTICE: GL: NPOT texture support detected
06:28:02 T:1932198688 NOTICE: Previous line repeats 2 times.
06:28:02 T:1932198688 NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 21
06:28:12 T:1855873904 NOTICE: Previous line repeats 2 times.
06:28:12 T:1855873904 NOTICE: CDVDPlayer::CloseFile()
06:28:12 T:1855873904 NOTICE: DVDPlayer: waiting for threads to exit
06:28:12 T:1933283656 NOTICE: CDVDPlayer::OnExit()
06:28:12 T:1933283656 NOTICE: Closing stream player 1
06:28:12 T:1933283656 NOTICE: Waiting for audio thread to exit
06:28:12 T:1932198688 NOTICE: thread end: CDVDPlayerAudio::OnExit()
06:28:12 T:1933283656 NOTICE: Closing audio device
06:28:12 T:1933283656 NOTICE: Deleting audio codec
06:28:12 T:1933283656 NOTICE: Closing stream player 2
06:28:12 T:1933283656 NOTICE: waiting for video thread to exit
06:28:12 T:1943091344 NOTICE: thread end: video_thread
06:28:12 T:1933283656 NOTICE: deleting video codec
06:28:13 T:1855873904 NOTICE: DVDPlayer: finished waiting
06:28:13 T:1855873904 NOTICE: CDVDPlayer::CloseFile()
06:28:13 T:1855873904 NOTICE: DVDPlayer: waiting for threads to exit
06:28:25 T:1855873904 NOTICE: Storing total System Uptime
06:28:25 T:1855873904 NOTICE: Saving settings
06:28:25 T:1855873904 NOTICE: stop all
For the past few days, I have not been able to use this app. Either I get a message that says 'Unable to play..' or it just looks like its loading and does nothing. I am not sure if this is identical to whats already been reported. Please help!
13:07:49 T:18446744071689769088 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://mlblive-l3c.mlb.com/ls04/mlbam/2016/04/17/MLB_GAME_VIDEO_TORBOS_HOME_20160417/4500K/4500_complete.m3u8|User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b89022e52cbc63762affa03340cf8913ef9e561d4fa24c174b6b58272eaaae398d817cf830b7cd2c7398e7c0c3ee5e2ffa58ddf6b229d42e92f633b09ffd75c8a1aa08e89a13079386db11837509a2711afa9a698cd42e22d9db7b1922460f8bb2da763db39a9d1246423be66d29b58607b33314091a3781a67b938cd1af6006f1b89fc5b24ae04e48480b31d347761eaa458193c914440783cf61f0331771ab503bde426d89d9af0bd7aa08be88673074a5b11ec8e5d20a1e4cab599857a153ce2e19ad71a3877960>
13:07:49 T:18446744071689769088 NOTICE: Creating Demuxer
13:07:50 T:18446744071689769088 ERROR: bool CDVDPlayer::OpenDemuxStream() - Error creating demuxer
13:07:50 T:18446744071689769088 NOTICE: CDVDPlayer::OnExit()
13:07:50 T:18446744072443575168 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFFF69E20%5DPre-Game%5B%2FCOLOR%5D+TOR+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D+at+BOS+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D&event_id=14-447050-2016-04-17&gid=2016%2F04%2F17%2Ftormlb-bosmlb-1&teams_stream=torbos&stream_date=2016-04-17]
13:07:50 T:18446744072443575168 NOTICE: CDVDPlayer::CloseFile()
13:07:50 T:18446744072443575168 NOTICE: DVDPlayer: waiting for threads to exit
13:07:50 T:18446744072443575168 NOTICE: DVDPlayer: finished waiting
13:07:50 T:18446744072071625600 NOTICE: Stream All The Sources: Service: Playback Stopped
13:08:28 T:2127775360 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/lates...ormwarning.
13:11:51 T:18446744071573776128 ERROR: Previous line repeats 1 times.
13:11:51 T:18446744071573776128 WARNING: Attempt to use invalid handle 50
13:11:52 T:18446744072443575168 NOTICE: DVDPlayer: Opening: http://mlblive-l3c.mlb.com/ls04/mlbam/20...pplication libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b8e58dc7a74c5b50bfe5c545b6e34bf03ee6a506854ead9b850b9cd864692e492b315f5bff963e7e405084bb9b89fd1315e5b97aaf7c5ee9847b68506cf611e3694b92ceeb9c0994905daa86aad66f817ee9d002ea10bd61fce8278cb0e346f4602b5fcb8c56ee2e05059da17207254498ff7ae188857562c089cd6c27eb04e03c5bdb57b62ca1151a0cc64e7267ce9b06650480fc1733f475d0ffb74be7b0c46d
13:11:52 T:18446744072443575168 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
13:11:52 T:18446744071690164352 NOTICE: Creating InputStream
13:11:52 T:18446744071690164352 ERROR: CCurlFile::Open failed with code 404 for http://mlblive-l3c.mlb.com/ls04/mlbam/20...pplication libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b8e58dc7a74c5b50bfe5c545b6e34bf03ee6a506854ead9b850b9cd864692e492b315f5bff963e7e405084bb9b89fd1315e5b97aaf7c5ee9847b68506cf611e3694b92ceeb9c0994905daa86aad66f817ee9d002ea10bd61fce8278cb0e346f4602b5fcb8c56ee2e05059da17207254498ff7ae188857562c089cd6c27eb04e03c5bdb57b62ca1151a0cc64e7267ce9b06650480fc1733f475d0ffb74be7b0c46d
13:11:52 T:18446744071690164352 ERROR: virtual bool XFILE::CFileCache::Open(const CURL&) - failed to open source <http://mlblive-l3c.mlb.com/ls04/mlbam/2016/04/17/MLB_GAME_VIDEO_ATLMIA_HOME_20160417/4500K/4500_complete.m3u8|User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b8e58dc7a74c5b50bfe5c545b6e34bf03ee6a506854ead9b850b9cd864692e492b315f5bff963e7e405084bb9b89fd1315e5b97aaf7c5ee9847b68506cf611e3694b92ceeb9c0994905daa86aad66f817ee9d002ea10bd61fce8278cb0e346f4602b5fcb8c56ee2e05059da17207254498ff7ae188857562c089cd6c27eb04e03c5bdb57b62ca1151a0cc64e7267ce9b06650480fc1733f475d0ffb74be7b0c46d>
13:11:52 T:18446744071690164352 NOTICE: Creating Demuxer
13:11:53 T:18446744071690164352 ERROR: bool CDVDPlayer::OpenDemuxStream() - Error creating demuxer
13:11:53 T:18446744071690164352 NOTICE: CDVDPlayer::OnExit()
13:11:53 T:18446744072443575168 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFFF69E20%5DT+1st%5B%2FCOLOR%5D+ATL+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D+at+MIA+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D&event_id=14-447038-2016-04-17&gid=2016%2F04%2F17%2Fatlmlb-miamlb-1&teams_stream=atlmia&stream_date=2016-04-17]
13:11:53 T:18446744072443575168 NOTICE: CDVDPlayer::CloseFile()
13:11:53 T:18446744072443575168 NOTICE: DVDPlayer: waiting for threads to exit
13:11:53 T:18446744072443575168 NOTICE: DVDPlayer: finished waiting
13:11:53 T:18446744072071625600 NOTICE: Stream All The Sources: Service: Playback Stopped
13:12:58 T:2127775360 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:120: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/lates...ormwarning.
13:13:16 T:18446744071592240000 NOTICE: Kodi Log Uploader: started
(2016-04-17, 19:11)seanmack Wrote: [ -> ]For the past few days, I have not been able to use this app. Either I get a message that says 'Unable to play..' or it just looks like its loading and does nothing. I am not sure if this is identical to whats already been reported. Please help!
Same problem for me yesterday. No game at all would play.
Looks like your problem is specific to your platform which is not indicated in your posts (specifically the Python versions for your platform which causes the SSL error)
There are a few suggestions in this Stackoverflow thread if you wanted to attempt to fix this yourself http://stackoverflow.com/questions/29134...is-prevent
Update 2016.4.19 Released
- Free games are now highlighted green
- Changed wording on single team subscription to include free game subscription
- Added not authorized message when user attempts to request a stream their account is not authorized to access
- Added blackout lift time in blackout message if game has finished
- Added logic to catch a username or password change and perform a fresh login
(2016-04-19, 15:48)eracknaphobia Wrote: [ -> ]Update 2016.4.19 Released
Thank you eracknaphobia
Hi this plugin does not seem to work under Kodi 17 Alpha 1 (LibreElec build)
Reverting back down to the Kodi 16 Beta 1 build (from LibreElec) seemed to fix the issue. Nothing unusual (well from what's been posted before) in the logs:
21:19:24 8366.734375 T:139822625040448 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:19:24 8366.761719 T:139820125701888  NOTICE: Creating InputStream
21:19:24 8366.994141 T:139820125701888  NOTICE: Creating Demuxer
21:19:54 8397.048828 T:139820125701888   ERROR: OpenDemuxStream - Error creating demuxer
21:19:54 8397.048828 T:139820125701888  NOTICE: CVideoPlayer::OnExit()
21:19:54 8397.052734 T:139822625040448   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BB%5D%5BCOLOR%3DFFF69E20%5DB+7th%5B%2FCOLOR%5D+%5BCOLOR%3DFFAB0003%5DNationals%5B%2FCOLOR%5D+%5BCOLOR%3DFF00B7EB%5D7%5B%2FCOLOR%5D+at+Marlins+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D%5B%2FB%5D&event_id=14-447073-2016-04-19&gid=2016%2F04%2F19%2Fwasmlb-miamlb-1&teams_stream=wasmia&stream_date=2016-04-19]
21:19:54 8397.056641 T:139822625040448  NOTICE: CVideoPlayer::CloseFile()
21:19:54 8397.056641 T:139822625040448  NOTICE: VideoPlayer: waiting for threads to exit
21:19:54 8397.056641 T:139822625040448  NOTICE: VideoPlayer: finished waiting
21:22:02 8525.000977 T:139822625040448  NOTICE: VideoPlayer: Opening: http://mlblive-akc.mlb.com/ls04/mlbam/2016/04/19/MLB_GAME_VIDEO_WASMIA_VISIT_20160419/5000K/5000_complete.m3u8|User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=mediaAuth=a06e2dc0e366b956c91a6e3cab8762e8677e91491a59d08b2ba6bb275ebd21da4594d21e2a0f38b80a92919475fe3f50b85c4618ccebbed49dfc8d383793ed8d956118dbdbd448186dd192057f381d3eae886fa92608f269d23ff8554801bcefffdc30407524ac2a903a8f9fe02147f7df2edc8e67e8698c1f64133d31af155114d274d9b9cb5368cdf85cec5b9ca1433e6d7fe734a43e2c11d39bbd054dcb7956a6b08c11c2c886561d53f22ff8d8225dbcf89464debdf0ee3485e0bb9d8cba8e825eaa1387eea7
21:22:02 8525.000977 T:139822625040448 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:22:02 8525.026367 T:139820125701888  NOTICE: Creating InputStream
21:22:02 8525.237305 T:139820125701888  NOTICE: Creating Demuxer
21:22:04 8527.507812 T:139820125701888   ERROR: OpenDemuxStream - Error creating demuxer
21:22:04 8527.507812 T:139820125701888  NOTICE: CVideoPlayer::OnExit()
21:22:04 8527.514648 T:139822625040448   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BB%5D%5BCOLOR%3DFFF69E20%5DB+7th%5B%2FCOLOR%5D+%5BCOLOR%3DFFAB0003%5DNationals%5B%2FCOLOR%5D+%5BCOLOR%3DFF00B7EB%5D7%5B%2FCOLOR%5D+at+Marlins+%5BCOLOR%3DFF00B7EB%5D0%5B%2FCOLOR%5D%5B%2FB%5D&event_id=14-447073-2016-04-19&gid=2016%2F04%2F19%2Fwasmlb-miamlb-1&teams_stream=wasmia&stream_date=2016-04-19]
21:22:04 8527.532227 T:139822625040448  NOTICE: CVideoPlayer::CloseFile()
21:22:04 8527.532227 T:139822625040448  NOTICE: VideoPlayer: waiting for threads to exit
21:22:04 8527.532227 T:139822625040448  NOTICE: VideoPlayer: finished waiting
21:22:04 8527.540039 T:139822625040448  NOTICE: CVideoPlayer::CloseFile()
21:22:04 8527.540039 T:139822625040448  NOTICE: VideoPlayer: waiting for threads to exit
21:22:04 8527.541016 T:139822625040448  NOTICE: VideoPlayer: finished waiting
Not sure if it's related to the DVDPlayer temporarily being disabled in 17 Alpha 1 but other video plugins work fine (e.g., USTV VOD).
I can re-update back to Kodi 17 and provide full debug log if it would be helpful.
Games all working good here again... thx for the update.
Is it possible to make a playlist of recap videos?
Thanks for the great updates.
In trying to install on new device, I came across one potential problem. If the password to MLB.com is entered incorrectly, there does not seem to be a direct feedback that this is the case. The streaming will continue to fail with the "check log" message. Nothing in the log directly suggests the root cause but I see that a null URL is passed to the Player. If a direct check for successful login cannot be made, perhaps the URL passed to the player can be ensured to be non-null (which might happen many reasons) and perhaps a better feedback can be provided if known.at the time.
Using the latest release of the add-on.
