Full Version: MLB.TV®
(2016-03-08, 23:20)larshenric Wrote: [ -> ]Btw...: Going to Kodilogs.com the site tells me that the "domain is expired"... How does the Log Uploader work with an expired domain?
Not sure where you got that link from but here's an example of one that is created with the tutorial:
http://xbmclogs.com/ptu6opqwy
On The Apple TV 4 the was updated. New Features like Picture in Picture and seems 60 fps.
(2016-03-08, 23:33)eracknaphobia Wrote: [ -> ]
That was no sent link... It's the web adress the add-on "Log Uploader" tells me where my log is supposed to be sent to... And as the add-on didn't send me any link I just went to that site to see what's behind it...
So, in conclusion: neither the mlb.tv-addon nor the Log Uploader-addon works for me...
Any suggestions?
Read step 6, it explains what to do.
http://kodi.wiki/view/Log_file/Easy
Note: If you don't get the e-mail link, just use the URL http://xbmclogs.com/#### where "####" is your ID code from the popup window.
Note: If you don't get any e-mail link and no window pops up with an ID number, then the site xbmclogs.org might be down and you might need to manually copy/paste your log file to http://pastebin.com instead. See Log file/Advanced#Location for how to locate the log file manually.
I'd also check your spam folder to see if the email was flagged
Unfortunately I don't get no email link and not even a pop up window. The Log Upöoader addon just doesn't react...
And I can't just copy/paste the log file, because Kodi is running on a Boxee Box, not on a computer... I can't access to the file... :-(
(2016-03-09, 23:19)larshenric Wrote: [ -> ]because Kodi is running on a Boxee Box, not on a computer... I can't access to the file... :-(
thought about getting help from your buddies at boxee to learn how? http://boxeed.in/forums
eracknaphobia thanks for creating this nice add-on, it shows great potential.
Been using it for past 4 days now to watch archived games and (unlike mlbmc) all are in 720p with no buffering, freezing or stuttering. Skipping ahead by skip steps or time seeking both work very well.
A nice refinement would be to make finding archived games easier, e.g. by calendar browsing rather than typing the full year-month-day.
If it works just as well with live games then more than happy to buy you some beers Smile Thanks again.
(2016-03-10, 03:29)fuggin Wrote: [ -> ]
Yes, I did... ;-)
The only thing concerning MLB on Boxee is MLBMC... And I thought that the addon mlb.tv could be something better than MLBMC, so I tried it...
But unfortunately it doesn't seem to work on Boxee...
(2016-03-10, 18:41)larshenric Wrote: [ -> ]Yes, I did... ;-)
it will never work until you get a debug log to eracknaphobia. You need the help of the boxee community to educate you on how to get the debug log off your poxee media center.
I'm new to Kodi so please forgive me if I'm asking stupid questions...
Although there are no stupid questions, only stupid people.
I installed Kodi today, downloaded your repo and installed it on my Android TV.
However, when I try to install from repository I get the message 'Could not connect to repository'.
Am I doing something wrong?
(2016-03-11, 17:57)RevJJ82 Wrote: [ -> ]Hi,
This is a zip file so you need to use the "install from zip file" option.
http://kodi.wiki/view/HOW-TO:Install_add..._zip_files
Yes, I did that (as mentioned in my post, but perhaps I was unclear). But after that, I have to install from repository, right? In order to get MLB.tv?
(2016-03-11, 18:16)RevJJ82 Wrote: [ -> ]Yes, I did that (as mentioned in my post, but perhaps I was unclear). But after that, I have to install from repository, right? In order to get MLB.tv?
After you install the zip file I believe you select install from repo, you should then see the eracnaphobia repo, open it and inside should be all his add-ons including mlb and nhl select the mlb addon, right click and select install. After installing you need to configure it, adding your log-in info.
That's the problem. When I try to open the repo, I get the message 'could not connect to repository'.
Sounds like the zip isn't installed correctly. Can you actually see the eracnaphobia repo? What kind of android device are you using?
