Full Version: MLB.TV®
I can see the Eracnaphobia repo, I get the error when I try to open it.
I am trying to run it on a Phillips Android TV with Lollipop 5.1.
I'm getting a Playback Failed when trying to play any game (live or archived). I'm a subscriber, and confirmed I can watch games on the website:
Full Log:
http://pastebin.com/raw/hxWLb7mV
10:48:36 T:6928 ERROR: Playlist Player: skipping unplayable item: 0, path [
Any way there could be a Highlight or Recap section? Thanks, this is incredible!
(2016-03-11, 20:59)GriffeyJuni0r Wrote: [ -> ]I'm getting a Playback Failed when trying to play any game (live or archived). I'm a subscriber, and confirmed I can watch games on the website:
Full Log:
10:57:12 T:3408 DEBUG: STREAM URL: |User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=
10:57:12 T:3408 DEBUG: STREAM BEFORE PLAY
10:57:12 T:3408 DEBUG: |User-Agent=PS4Application libhttp/1.000 (PS4) libhttp/3.15 (PlayStation 4)&Cookie=
Are your credentials correct? Looks like you aren't getting a valid stream returned. There should be a .m3u8 url before the "|User-Agent". Also the cookies parameter shouldn't be blank.
(2016-03-12, 01:03)IdiotSavante Wrote: [ -> ]Any way there could be a Highlight or Recap section? Thanks, this is incredible!
All the highlights and recaps I've found are tiny 10-30 second clips. Does anyone know of a place or device that offers full 3-5 minute highlights as one continuous video?
(2016-03-08, 20:47)larshenric Wrote: [ -> ]Hi!
I tried it with KODI on a Boxee Box... It installed (showing up as an Add-on...), but when I start the Add-on it tells me "script failed"
Hm...
So, I managed to create and copy a log:
http://pastebin.com/raw/dsZaJdLz
Hopefully help is possible now... ;-)
Quote:All the highlights and recaps I've found are tiny 10-30 second clips. Does anyone know of a place or device that offers full 3-5 minute highlights as one continuous video?
The old MLBMC Kodi Addon had this when you logged in. I'm not savvy enough to delve into the code, but I can sure try to find where he's getting his info. Tongue
Looks like it's pulling the highlights direct from the mlb.com website. Maybe from here. http://m.mlb.com/video/?game_pk=469578 (for example).
(2016-03-11, 20:24)RevJJ82 Wrote: [ -> ]I can see the Eracnaphobia repo, I get the error when I try to open it.
Anyone?
(2016-03-12, 15:10)eracknaphobia Wrote: [ -> ]
Full Log:
I figured out what the problem was - Initially, I used the wrong login credentials and then I switched them to the correct ones. It looks like the old cookie was saved, and the new correct one wasn't overwritten. I just deleted the cookies.lwp file, and restarted and it worked flawlessly. Thanks for your help!
(2016-03-12, 20:26)GriffeyJuni0r Wrote: [ -> ]
Full Log:
Good to hear. I should probably put a logout option in the settings so people can clear the cookies file from within the add-on.
(2016-03-12, 17:45)RevJJ82 Wrote: [ -> ]
Anyone?
Have you tried an uninstall / re-install on the repository zip itself? Other than that a log file would help.
Nothing works for me. Have tried two different mlb account logins I have. Either nothing loads or I get a playback error cannot load. Pleas help!
On a side note your nhl addon works great! Thanks for your continued efforts.
http://xbmclogs.com/pflfw2ico
Full Log:
I had the exact same problem. I tried uninstalling and re-installing multiple times. After I read this thread, I did another uninstall, and noticed that the mlb.tv user data wasn't removed on uninstallation. I deleted the user data, reinstalled the app, entered my CORRECT credentials, and everything is working!
Thanks for the help! Looking forward to seeing if this performs better then the MLB.TV app on my smart TV.
(2016-03-13, 21:09)iamwickid Wrote: [ -> ]Nothing works for me. Have tried two different mlb account logins I have. Either nothing loads or I get a playback error cannot load. Pleas help!
Ok so after deleting the cache file in the userdata of the app and re entering my credentials everything works! I think adding a delete cache option in the app would be ideal! Thanks to everyone.
(2016-03-08, 15:31)eracknaphobia Wrote: [ -> ]
(2016-03-08, 00:43)GriffeyJuni0r Wrote: [ -> ]Awesome! Another feature that would be great to have is audio overlay support. On the website you can overlay different audio feeds over the video (Radio broadcast audio over the TV broadcast video). Would this be possible to implement in this addon as well? If so, that would be amazing!
I saw that but I haven't been able to figure out how they do it yet. If there are dedicated streams for each video / audio option then it will be doable.
You're a much better coder than you thought - Looks like you already are parsing the audio streams. If you go into the audio settings once a game is playing you can switch the audio stream. I think these are the radio broadcasts. Right now, however, they are all listed as 'Unknown' so it would be awesome to get the names on the streams. Additionally, it would be great to select the particular video/audio stream on game select.
(2016-03-15, 05:12)GriffeyJuni0r Wrote: [ -> ]You're a much better coder than you thought - Looks like you already are parsing the audio streams. If you go into the audio settings once a game is playing you can switch the audio stream. I think these are the radio broadcasts. Right now, however, they are all listed as 'Unknown' so it would be awesome to get the names on the streams. Additionally, it would be great to select the particular video/audio stream on game select.
Interesting, although I can't take the credit for that Kodi is doing most of the work for me Wink I'll look into refining this in the next release.
