2017-04-12, 19:09
(2017-04-12, 17:54)Scott00007 Wrote: [ -> ]seems strange that you are even maintaining 2 versions.
Actually, it's a bonus that he does this. Most authors do not.
Thanks @erack for the extra effort!
(2017-04-12, 19:09)MetalChris Wrote: [ -> ](2017-04-12, 17:54)Scott00007 Wrote: [ -> ]seems strange that you are even maintaining 2 versions.
(2017-04-12, 15:38)eracknaphobia Wrote: [ -> ]Update 2017.4.12 Released
- Rolled back the stream urls to previous version (to fix commercial break issues)
- Lowered the python version so Jarvis users can install directly from my repo. So from now on all versions in my repo will support jarvis 16 and up and the version in the official kodi will be Krypton 17 and up
(2017-04-15, 02:12)matty8199 Wrote: [ -> ]random question - is there a way to get 60fps at 3500k? roku seems to be able to do this, i have it locked to 3.5mbps and it's still clearly 60fps smooth...wondering if this might help resolve the buffering issues some of us are still having. if i pick the 3500k streams in the kodi add-on, i'm never able to get 60fps...
(2017-04-15, 04:22)hhqjdaasc Wrote: [ -> ](2017-04-15, 02:12)matty8199 Wrote: [ -> ]random question - is there a way to get 60fps at 3500k? roku seems to be able to do this, i have it locked to 3.5mbps and it's still clearly 60fps smooth...wondering if this might help resolve the buffering issues some of us are still having. if i pick the 3500k streams in the kodi add-on, i'm never able to get 60fps...
Are you sure that your Roku is receiving 720p@60fps on the 3500kbps setting and not just upscaling everything to 60fps before outputting to your TV?
(2017-04-15, 06:43)matty8199 Wrote: [ -> ](2017-04-15, 04:22)hhqjdaasc Wrote: [ -> ](2017-04-15, 02:12)matty8199 Wrote: [ -> ]random question - is there a way to get 60fps at 3500k? roku seems to be able to do this, i have it locked to 3.5mbps and it's still clearly 60fps smooth...wondering if this might help resolve the buffering issues some of us are still having. if i pick the 3500k streams in the kodi add-on, i'm never able to get 60fps...
that's a good question, i have no idea. all i know it's definitely displaying at 60fps when i have the bitrate locked to 3500...
(2017-04-15, 07:03)hhqjdaasc Wrote: [ -> ](2017-04-15, 06:43)matty8199 Wrote: [ -> ](2017-04-15, 04:22)hhqjdaasc Wrote: [ -> ]Are you sure that your Roku is receiving 720p@60fps on the 3500kbps setting and not just upscaling everything to 60fps before outputting to your TV?
Is that frame rate being reported by the TV or by the Roku? One way to test that might be to select a lower bit rate on the Roku and see if it still says that you are getting 60fps - for instance set it to 450kbps and if it still says that you're getting 60fps then the Roku must be inserting frames. I could be mistaken, but AFAIK the only combinations of resolution and frame rate that MLBTV is streaming are 224/30p, 288/30p, 360/30p, 504/30p, 540/30p, 720/30p, and 720/60p. If you are seeing a combination of resolution and frame rate that is not on that list then something must be re-sampling the incoming stream.
(2017-04-15, 07:43)matty8199 Wrote: [ -> ](2017-04-15, 07:03)hhqjdaasc Wrote: [ -> ](2017-04-15, 06:43)matty8199 Wrote: [ -> ]that's a good question, i have no idea. all i know it's definitely displaying at 60fps when i have the bitrate locked to 3500...
to be honest i haven't even checked to see what the reported frame rate is...i can just tell it's 60fps. it looks identical to my directv feed.
i spent years watching it at 30fps, where it was obviously more jittery than the satellite feed. i know this is smoother than that...i'll check it next time i'm upstairs, though.
(2017-04-15, 08:39)hhqjdaasc Wrote: [ -> ](2017-04-15, 07:43)matty8199 Wrote: [ -> ](2017-04-15, 07:03)hhqjdaasc Wrote: [ -> ]Is that frame rate being reported by the TV or by the Roku? One way to test that might be to select a lower bit rate on the Roku and see if it still says that you are getting 60fps - for instance set it to 450kbps and if it still says that you're getting 60fps then the Roku must be inserting frames. I could be mistaken, but AFAIK the only combinations of resolution and frame rate that MLBTV is streaming are 224/30p, 288/30p, 360/30p, 504/30p, 540/30p, 720/30p, and 720/60p. If you are seeing a combination of resolution and frame rate that is not on that list then something must be re-sampling the incoming stream.
Even 30fps should not have obvious stuttering or flickering. How does the 5000kbps feed look you in Kodi compared to DirectTV?
btw, in kodi you can see all the tech specs of the feed by pressing O on the keyboard.
(2017-04-14, 02:18)eracknaphobia Wrote: [ -> ]You think changing one line of code results in a poorer version? I don't think you understand how this actually works...
