Full Version: MLB.TV®
Oh ok so it should work now? Thanks
Well I'm talking about the official mlb app being updated.  Seems as if the mlb.tv kodi addon needs a fix of some sort now.
Everything is working great for me now, except I can't use the alternate audio during live operation.
Ohh okay I see. Thanks! Yup probably needs to me tweaked a bit the addon that is
(2018-03-21, 05:11)brettbutlerisok Wrote: [ -> ]Everything is working great for me now, except I can't use the alternate audio during live operation.
 So, you don't have the issue of the same commercial fragment playing over ten times between innings?
I'm curious as to what is causing that. If I watch in a browser (with ad-blocker off), commercials play normally.
The addon was working fine for me yesterday but not today.
(2018-03-21, 05:21)architeuthis Wrote: [ -> ]
I do have the commercial fragments, but the game plays fine after the commercials.
This new Best Western Ad seems to be causing the old problem, when the game comes back it sputters.
he all, I have tried to use this addon. I have put in my credentials in the config. When I select a game I can only select Highlight. When I choose these I get a Failure, see log for more information.
Help?
Thank You ... same issue. I thought I was doing something wrong. Though the MLB.tv app on my NVidia Shield is working fine.
Cannot find an app for android lollipop or samsung smart tv anymore, so i hoped this would work. But unfortunatly not. And i just dont like at bat.
Bummed out.
(2018-03-25, 23:47)Rickyuu Wrote: [ -> ]Bummed out.
 Apt description of average MLB.tv user.  I can't believe they discontinued archives for Gameday Audio, and audio overlay!
I am having no luck with the MLB.TV Kodi Add-On.  I can log into the website and watch fine, but when I try to use the Add-On, The only option I get for a game, is HIGHLIGHTS and if I click on Highlights, I get Playback failed Error..
09:56:27.635 T:9516   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFF666666%5DFinal%5B%2FCOLOR%5D+Marlins+%5BCOLOR%3DFF00B7EB%5D3%5B%2FCOLOR%5D+at+Mets+%5BCOLOR%3DFF00B7EB%5D4%5B%2FCOLOR%5D&event_id=14-534240-2018-03-25&gid=2018%2F03%2F25%2Fmiamlb-nynmlb-2&teams_stream=mianyn&stream_date=2018-03-25]
09:56:28.510 T:3500   ERROR: EXCEPTION: XBMC is not playing any file
09:58:02.782 T:12936   ERROR: Previous line repeats 94 times.
09:58:02.782 T:12936  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
09:58:03.592 T:3500   ERROR: EXCEPTION: XBMC is not playing any file
10:03:08.164 T:12936   ERROR: Previous line repeats 304 times.
10:03:08.164 T:12936  NOTICE: AddOnLog: PVR IPTV Simple Client: EPG Loaded.
10:03:08.976 T:3500   ERROR: EXCEPTION: XBMC is not playing any file
10:07:38.933 T:11980   ERROR: Previous line repeats 269 times.
10:07:38.933 T:11980   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.UnboundLocalError'>
                                            Error Contents: local variable 'highlights' referenced before assignment
                                              File "C:\Users\PWM\AppData\Roaming\Kodi\addons\plugin.video.mlbtv\main.py", line 956, in <module>
                                                streamSelect(event_id, gid, teams_stream, stream_date)
                                              File "C:\Users\PWM\AppData\Roaming\Kodi\addons\plugin.video.mlbtv\main.py", line 381, in streamSelect
                                                for i in range(0,len(highlights)-1):
                                            UnboundLocalError: local variable 'highlights' referenced before assignment
10:07:39.032 T:9516   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.mlbtv/?mode=104&name=%5BCOLOR%3DFF666666%5DFinal%5B%2FCOLOR%5D+Marlins+%5BCOLOR%3DFF00B7EB%5D3%5B%2FCOLOR%5D+at+Mets+%5BCOLOR%3DFF00B7EB%5D4%5B%2FCOLOR%5D&event_id=14-534240-2018-03-25&gid=2018%2F03%2F25%2Fmiamlb-nynmlb-2&teams_stream=mianyn&stream_date=2018-03-25]
10:07:39.200 T:3500   ERROR: EXCEPTION: XBMC is not playing any file
If you haven't already, try using eracknaphobia's 'my repo' link to install the add-on.
Seems they've implemented blackout restrictions today even though these are still spring training games.
